Author Topic: Backing up Outlook made simple tool  (Read 1822 times)
« on: August 14, 2003, 11:39 »
Always feared your HDD going walkabout and taking years of Outlook data with it. All those Personal folders, all the content of same gone into cyber space never to return  :'(  :tony:
Well fear no more, what you need is Outlook pst.Backup. You download this self installing little program, well you have to click the 'Run' button  ::) And you will then find it under File in Outlook, it's called, wait for it..................Backup  :)  You can set it to remind you to backup you Personal folders say every 7 days or whatever, neat eh?
Download it HERE I think it is the seventh download down the list.
Re:Backing up Outlook made simple tool
« Reply #1 on: August 14, 2003, 16:37 »
Done!  Thanks, Tony. :)
« Reply #2 on: August 14, 2003, 16:40 »
Sh1t!  That's what happens when you are doing things on the PC and making dinner at the same time.  I can't get it to work in Office 2000.   :(
« Reply #3 on: August 14, 2003, 16:46 »
Yippee!  Got it now.  Must have had a dodgy download forst time. :)
Offline DJ
« Reply #4 on: August 14, 2003, 16:54 »
Which download is it for Office 2000 chorleydave?
I tried before but it didn't work  :(
Let me know - cheers  ;)
DJ
« Reply #5 on: August 14, 2003, 17:42 »
Hi, DJ.  The link below should take you directly to it.  If you can't get it, PM me an e-mail address and I'll e-mail it to you.  It's less than 200KB.
http://office.microsoft.com/downloads/2002/pfbackup.aspx
Edit:  Lol, I posted this  then noticed you had already PM'd me.   I'll send it now.
Offline DJ
« Reply #6 on: August 14, 2003, 22:48 »
:thanks: Chorleydave, I got your email and it works a treat
Cheers  ;)
DJ
