Author Topic: Another prob I have - Missing files?  (Read 2522 times)
Offline Michelle
    • Techieminx
« on: August 14, 2003, 13:28 »
Hi all
Another problem I've had which I've searched these boards for but can't see is ....
Alot of my files mainly I'd say downloaded ones don't appear in the folder that I put them in unless I "search" for them?  If I open the same folder in search and not on the desktop there's a tonne of files there that don't appear when I open the same folder on the desktop. ??? (does that make sense?)  Any idea how I can make them show up?  I'm using Window's Millenuim.
Michelle
Re:Another prob I have - Missing files?
« Reply #1 on: August 14, 2003, 13:34 »
Cant think why its doing that Michelle unless you have it set to NOT show all files.
If you open a folder and go to TOOLS then FOLDER OPTIONS then VIEW,scroll down the list until you see SHOW ALL FILES,tick that and see if it helps :doggie:
« Reply #2 on: August 14, 2003, 13:35 »
Have you set your system up to "Show All Files", Michelle?
My Computer > View > Folder Options then click on view tab and put a tick in "Show All Files".
Offline Michelle
    • Techieminx
« Reply #3 on: August 14, 2003, 13:48 »
Thanks guys but
it does say show all files and folders - there's not one that actually says show all files though?
All the rest are ticked apart from launch folder windows in separate process
« Reply #4 on: August 14, 2003, 14:02 »
Hi Michelle.
Is the one that says "Show All Files and  Folder" ticked?
Offline Michelle
    • Techieminx
« Reply #5 on: August 14, 2003, 14:14 »
ah I mean't to say
"show hidden files and folders" is checked   I don't have one that says "show all folders"
sorry lol
Offline Michelle
    • Techieminx
« Reply #6 on: August 14, 2003, 22:24 »
Please ignor this post now
erm......... I'm blonde okay  :blonde:
Its all fine now, thanks guys xxxxx
« Reply #7 on: August 14, 2003, 22:39 »
Blonde?  Damn!  And just as we were about to appoint you as Local Mod of the Tech section, too.
Thank God you told us in time!   ::)
Offline Michelle
    • Techieminx
« Reply #8 on: August 14, 2003, 22:43 »
:-* Rodders
« Reply #9 on: August 14, 2003, 23:09 »
Yes?   ???
Offline Michelle
    • Techieminx
« Reply #10 on: August 14, 2003, 23:14 »
Was just blowing you a kiss for that lovely post  :D
Not much more i could say to that  :P
« Reply #11 on: August 14, 2003, 23:31 »
Gosh!  Thank you honeybunch -- I needed that!   ;D
