Author Topic: Anyone heard of incredimail?  (Read 1665 times)
Offline Shaz
« on: August 15, 2003, 10:57 »
Hi Peeps,My mates sent me this link www.incredimail.com
You have to download it and apparently you can modifiy your e-mails!
Im a bit worried that if I do I might end up moithered to death with popups and bonzi buddy type hassle! :( Just wondering if anyone else has used it and if so is it any good! :)
een away but back with a vengence!!!!
Re:Anyone heard of incredimail?
« Reply #1 on: August 15, 2003, 11:53 »
Yes, many of us have used it Shaz.  The free version does contain ads, but it's not spyware.  What it is, is a novelty e-mail program, in the way that Outlook Express is a basic e-mail program.  You download it, and set up your e-mail accounts in the same way as you would OE, then you can use IncrediMail as your default e-mail program.  It's nice if you want lots of decorative backgrounds to your e-mails, or fun animations and sounds.  It also contains loads of smilies.  It is actually quite good fun, and has all the basic functions you need in an e-mail program.  It certainly won't hurt to give it a try.
Offline Shaz
« Reply #2 on: August 15, 2003, 12:05 »
Thanks for that Simon!Ill give it a go and let you know what I think,Ill proberbly love it if its got loads of smilies ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline Shaz
« Reply #3 on: August 15, 2003, 12:07 »
Just noticed your new pic :pmsl:
Offline Michelle
    • Techieminx
« Reply #4 on: August 15, 2003, 12:25 »
I use incredimail too - its great fun with lots of extra's - I like the different ways it tells you have have mail.
Have fun
« Reply #5 on: August 15, 2003, 12:47 »
I used it too, Shaz. It's a very interesting program. But I decided to remove it because I've got a problem. I'm not very sure that it was something wrong in it. But it appeared to me so. Many mails that I have received, I wanted to open, I was unable to find them in "Incoming mail". I found them already in the bin. That didn't happen always. It happened after some installations. (Because I installed and removed it many times.) Some other times, it worked nicely. (Could be something wrong in my configurations to it or to an other program.) May be it was because of a small conflict between it and "Outlook Express". Anyway, I'm not yet sure of the cause. I think that, in the future, I'm going to reinstall it, because I like it.
