Author Topic: Hole Saw  (Read 1440 times)
Offline Robotochan
Hole Saw
« on: August 16, 2003, 13:23 »
Anyone know where I can get a cheap hole saw to cut a hole in 5mm Acrylic for a 120mm fan? Everyone is selling ones for steel for £15 - £25 online  :-\
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:Hole Saw
« Reply #1 on: August 16, 2003, 13:33 »
Robot.. how good are you with a drill and half round file.
Mark out the area with a compass and drill holes around the inside of the Circumference then knock the inside piece out and smooth the rough edges with the half round file until you get to the marked line.. its a bit fiddly but saves the penny's M8.
Hookstar
Offline Robotochan
Re:Hole Saw
« Reply #2 on: August 16, 2003, 13:36 »
I not very good with any power tools  ;D But luckily my mate is skilled with them and his modders best friend the Dremel  ;D
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:Hole Saw
« Reply #3 on: August 16, 2003, 13:41 »
Dremel!! now that is cheating  :P
Offline Robotochan
Re:Hole Saw
« Reply #4 on: August 16, 2003, 13:47 »
And you saying a friend who is taking Advanced higher Graph Com and Art isn't? :heehee: :baad:
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:Hole Saw
« Reply #5 on: August 16, 2003, 13:53 »
Is that an "In" joke.. what have I missed  :P
