Author Topic: DETECT NEW HARDWARE.... shortcut?  (Read 1693 times)
Offline ketamininja
« on: August 22, 2003, 15:16 »
In XP, if you go to the device manager, you can "scan for new hardware", ie if I've just plugged a new hard drive in my caddy to the system without restarting.
If you've not used this feature already, it's very nice.
Does anyone know if you can create a desktop shortcut icon for this?
I've been meaning to ask this for ages!!!
Thanks.
Re:DETECT NEW HARDWARE.... shortcut?
« Reply #1 on: August 22, 2003, 18:38 »
Keta.. it cant be this simple can It :(.. or have I misunderstood the Question  ;D as per usual  :D
Hookstar  8)
« Reply #2 on: August 22, 2003, 18:46 »
:-[ just read it again.. yep I have  :aarrgh:
Offline ketamininja
« Reply #3 on: August 22, 2003, 21:42 »
nope sorry... this is the only known way (to me) to do what I want to do. well there is another way ... basically the same.
Windows Flag Key and Pause/Break --> Brings up System Properties.
Click Hardware Tab, select Device manager.
RMB your SYSTEM ROOT, select SCAN FOR NEW HARDWARE.
Its not really that long, but I do a lot of caddy shifting each day.
Offline ketamininja
« Reply #4 on: August 29, 2003, 12:48 »
No suggestions then? :(
I'll ask around, and I'll get back to you!
Offline ketamininja
« Reply #5 on: August 29, 2003, 15:24 »
http://www.geocities.com/deonvdw/RescanHardware.htm
This is a program someone has made... in VB I presume. Looks very simple.
I also found the run command somewhere, call a DLL with various parameters.
« Reply #6 on: August 29, 2003, 16:10 »
Is that only for SCSI K or do you think its for all hardware  ???
Offline ketamininja
« Reply #7 on: September 01, 2003, 12:33 »
It works for IDE.
Because XP overrides the BIOS, you should be able to detect any hotplug item, SCSI, IDE... possibly COM port items too.
