Author Topic: HP all in one Printers/Scanners  (Read 1697 times)
« on: August 23, 2003, 16:49 »
If anybody is having problems with an HP 750 all-in-one which continually receives message "Scanner not found" should connect printer to it's own power supply directly into wall.  I have been having problems for ages which I could not resolve but after removing it from multi point and giving it it's own power supply I have not had any more problems.  HP are receiving a lot of flack regarding this issue :(
Re:HP all in one Printers/Scanners
« Reply #1 on: August 23, 2003, 18:01 »
What a strange solution to your problem Lona  :-\
At least it is working now I suppose :D
« Reply #2 on: August 23, 2003, 18:04 »
By multipoint do you just mean one of those trailing 4 or 6 way sockets Lona or is it some weird and wonderful HP thing  ???
« Reply #3 on: August 24, 2003, 13:00 »
The good news is Scanner stayed connected for 1 day.  The bad news is, it's gone again :(
http://h20015.www2.hp.com/en/document.jhtml?lc=en&docName=bpu02181&prodId=hppsc750pr28086&cc=us#P40_3786
« Reply #4 on: August 24, 2003, 18:49 »
Lona.. by any chance is the scanner connected by a USB lead ?
« Reply #5 on: August 24, 2003, 19:00 »
Lona.. have you tried this ONE
« Reply #6 on: August 25, 2003, 00:39 »
I've read that one till I am blue in the face, Hook. I did everything they told me to do and it's still crap. Read this one
http://forums.itrc.hp.com/cm/QuestionAnswer/1,,0xdc205bd3782dd711abdc0090277a778c,00.html
« Reply #7 on: September 04, 2003, 02:11 »
PLEASE, PLEASE, is there anybody got an hp psc 750 that cannot load scanner. :(. I am at my wits end and don't know what else to try. :'(
« Reply #8 on: September 04, 2003, 02:17 »
I really think that you need to try it on another PC Lona to see if its faulty or not  ???
« Reply #9 on: September 05, 2003, 22:39 »
I'm beginning to think your right, Sandra. There are lots of others who have my problem and I can only think it is a design fault.
« Reply #10 on: September 07, 2003, 22:26 »
Just thought I would give you an update on my Scanner problems.  I found a message on HP forums that if I went into the Bios and changed Bi-directional to ECC or EPP it would solve the problem. Something to do with twain not connecting with the scanner.  I really didn't know what I was doing but thought, what the hell, and it worked. My scanner and printer is now fully operational. :D
PS until the next time  ;)
« Reply #11 on: September 07, 2003, 23:37 »
:welldone:  Lona!  These things always work out in the end!   :D
« Reply #12 on: September 08, 2003, 00:52 »
Yo Lona's a Techie...Lona's a Techie  ;)
Well one Lona  :-*
« Reply #13 on: September 08, 2003, 23:34 »
Well one Lona  :-*
I'm learning something new everyday, Tony. :). See, I don't just do quizes all the time.  :P
