Author Topic: My New Project  (Read 5503 times)
My New Project
« on: August 24, 2003, 20:21 »
Inspired by The Chuckle Brothers' forays into the world of PC building (nice thread Tony and Simon!), I've decided to upgrade my system to something half decent.
My current spec is an Athlon 1.3GHz, 512MB PC2100 DDR, 40GB, 15GB and 30GB HDDs, Gainward GeForce 4 MX440 64MB "Golden Sample", Creative 5.1 sound card, RAID and  Firewire.
A few things bother me about my current setup:-
    • The beige case is boring, boring, boring :o
    • The noise from the PC is deafening. I want to be able to leave the PC on all the time without upsetting the family
    • The case does not have enough 3.5" carriers for all my HDDs - I'll be adding more later!
    • the 1.3GHz CPU is a little slow for some of the apps I use (video editing). My present mobo will take up to Athlon XP2000+ but no more.
    • I'd like extra USB ports (only 2 at present) and I'd like them front mounted
    • a headphone socket on the front panel would be nice
    • I fancy a change ;)
    So I bought this case from Ebuyer @ £43.19.  As you'll see from the photo, it is a brushed stainless steel case with a perspex cutout side panel. But the crowning glory are the two multicoloured bubble efect tubes at either side of the case, which cycle colour between red, blue, white, yellow and green ::)
    Definitely not boring ;) The case takes 4 5.25" devices and has 4 internal HDD bays and 2 x 3.5 floppy disk type bays. All the edges in the case are rolled - no bloody fingers!
    There are only two minor gripes with the case:-
    • the drives have to be screwed into place - there are no quick release drive rails :(
    • the supplied 350 watt PSU is a little noisy
    My existing CD-ROM and CD-RW don't exactly go with the rest of the case, but EBuyer now have stock of these Coolermaster Universal Silver Bezels @ £7.96 each, so I have two on order, arriving Friday ;)
    Since the Akasa CPU fan I had was incredibly noisy, I replaced it with one of these @ £11.11. The Coolermaster Aero 7 Lite is an excellent fan, rated for up to Athlon XP 3200+. It has a vertically mounted fan rather than the normal horizontally mounted one. This fan has been redesigned for quieter operation and using the supplied rheostat, you can trun down the speed of the fan to a level of noise and CPU temperature that suits you best. I have set mine for near silent operation which maintains a constant 53 degC temperature.
    So I have the case sorted out - all I need now is a new motherboard, CPU and memory. I've been looking at this Epox 8RDA3G. Does anyone have any experience of this board (or for that matter any Epox board)? I'm probably going to get an AMD Atlon XP 2600+ CPU and a pair of Crucial PC2700 DDR memory chips to go with it. What do you think?
    Re:My New Project
    « Reply #1 on: August 24, 2003, 20:30 »
    Adept..looks good.. xtra usb ports in front  ;D
    Re:My New Project
    « Reply #2 on: August 24, 2003, 20:33 »
    Dont you just hate these show offs and Hookie even has to have his usb memory stick showing too  ::)
    Re:My New Project
    « Reply #3 on: August 24, 2003, 20:34 »
    Ah! But that's where I keep my knob Hookstar :o
    You know the one for slowing down the processor fan ;) :D
    Re:My New Project
    « Reply #4 on: August 24, 2003, 20:38 »
    No Sandra .. thats my IR usb for the IR on the Phone for downloading pics.
    Re:My New Project
    « Reply #5 on: August 24, 2003, 20:40 »
    Flaher git than I thought then Hookie  :P
    Re:My New Project
    « Reply #6 on: August 24, 2003, 20:41 »
    I'm thinking of getting a Bluetooth dongle for the very same purpose. Can't justify the £30 yet though :(
    Re:My New Project
    « Reply #7 on: August 24, 2003, 20:42 »
    Isnt your present dongle good enough for you and Lady Adept then  ;)
    Re:My New Project
    « Reply #8 on: August 24, 2003, 20:49 »
    Im hoping to order Thison Tuesday..
    The IR usb was only £14 and the 4 port USB was £10.
    Hookstar
    Re:My New Project
    « Reply #9 on: August 24, 2003, 20:52 »
    Ooooh pretty  :) I like the silver version.
    2 questions - how much and where from ;)
    Re:My New Project
    « Reply #10 on: August 24, 2003, 21:06 »
    Looking good, Sean.   ;)  I have to admit, I do like the case!   :D
    Re:My New Project
    « Reply #11 on: August 24, 2003, 21:09 »
    The photo doesn't do it justice either. I'm going to have to totally rearrange my desk space so that I can show it off ::)
    Re:My New Project
    « Reply #12 on: August 24, 2003, 21:22 »
    That's the trouble isn't it?  Most people's cases end up under the desk, which is a shame if it's a....
    .... oh buggerrr,  I've just dropped a pizza onnn my keyboard!   :o :o :o
    Re:My New Project
    « Reply #13 on: August 24, 2003, 21:24 »
    That's a very nice case, Sean.  It must have taken you absolutely ages to find one that matched Simon's sig.
    Offline Camstop
    Re:My New Project
    « Reply #14 on: August 24, 2003, 21:28 »
    I thought the idea was to look at the monitor...not the case.... ???
    Get one of these Sean.... ;)
