Author Topic: KaZaA  (Read 2017 times)
Offline Serenity
KaZaA
« on: August 25, 2003, 17:01 »
I need some help guys and before you all scream  ::) its to do with KaZaA  :o
I know a lot of you arent very fond of this program but  ive always liked using it BUT im having problems trying to get it to run on various screen settings so i thought Id uninstall it and re-install it again however for some reason it WONT uninstall  :-\
I keep getting THIS message in pop up box:
Error loading C:\windows\system32\cd_clint.dll  The specified module could not be found  :-[
Any ideas how I can delete it?  :-*
Re:KaZaA
« Reply #1 on: August 25, 2003, 17:08 »
Are you using Kazaa or Kazaalite, Serenity?
If you are using Kazaalite, the .dll file you specify is actually a dummy file which has to be present for Kazaalite to work.  It may be that you have protected the file using AdAware or another Anti-Spyware program, as they do pick it up.  If you do have Adaware, I would first check to see that is hasn't been protected by the program.
Re:KaZaA
« Reply #2 on: August 25, 2003, 17:22 »
Just been having a mooch and found this.
http://www.phazeshift.pwp.blueyonder.co.uk/files/kazaauninstallfix.exe
Haven't used it so don't forget to virus check it.
Re:KaZaA
« Reply #3 on: August 25, 2003, 17:26 »
Or try kazaAbegone from HERE
Offline Camstop
Re:KaZaA
« Reply #4 on: August 25, 2003, 21:37 »
Ok...The problem is.. ::)....If you run spybot or ad-aware it removes that dll file and wont run or uninstall... >:(
The solution is to reinstall Kazaa and it will put the file back on then you can un-install it before you run spybot and ad-aware.... ;) :-*
Re:KaZaA
« Reply #5 on: August 25, 2003, 21:50 »
It wont let her re install it now Cammy  :(
Re:KaZaA
« Reply #6 on: August 25, 2003, 22:07 »
That's a pity, because although I uninstalled Kazaalite the same day as I last installed it (after the first two files I got from it had viuses) I must have run AdAware as soon as I installed it, because I have found a copy of cd_clint.dll in my Adaware quarantine area.  Although it is a dummy copy, it would have been enough to trick AdAware into thinking the genuine .dll file was present.
Re:KaZaA
« Reply #7 on: August 25, 2003, 22:16 »
Re:KaZaA
« Reply #8 on: August 25, 2003, 22:20 »
She has done Hookie,but its still showing in add/remove bit even after it has searched and destroyed all files relating to kazaa  :(
Re:KaZaA
« Reply #9 on: August 25, 2003, 22:23 »
Time for RegClean, or a similar product, perhaps?   :D
Re:KaZaA
« Reply #10 on: August 25, 2003, 22:29 »
 I'm with you on this one Rodders, old chap.  ;D
Re:KaZaA
« Reply #11 on: August 25, 2003, 22:40 »
Before regclean.. try THIS
Hookstar
Re:KaZaA
« Reply #12 on: August 25, 2003, 23:33 »
Another candidate for the 'Safe Computing' page, methinks.  Cheers, Hooky!   ;)
Re:KaZaA
« Reply #13 on: August 25, 2003, 23:36 »
An excellent idea.  Go for it Rodders.
