Author Topic: Gphx card error  (Read 1259 times)
Gphx card error
« on: August 31, 2003, 18:44 »
GeForce 4 MX440 8x 128Mb DDR VGA+DVI + TV Out[/u]
This is on the build I recently did for a mate.  He tried to play a DVD last night, and received the following error message:
The TV out port of your TV display card is not working properly. This copy protected disc cannot be played when the TV out port is being utilised.
He was not using the TV Out port, as he was playing the DVD on his PC.  I had a look round on Google, and found somewhere that advised to update display drivers, which he did.  The error message has gone, but now he has no sound when playing a DVD with Power DVD software, but it seems to work OK with Windows Media Player (I didn't even know WMP played DVDs!)
Just as a talking point really, as the problem seems to have (sort of) been solved, has anyone  any ideas about this error message, and why there is now no sound with Power DVD?  Also, if WMP can play DVDs, how does it cope with different regions?
Re:Gphx card error
« Reply #1 on: August 31, 2003, 18:55 »
Well I know the answer to this bit ::)
When you set your region in the Regional and Language options section of control panel, Windows assumes which DVD region you wish to set. Everything you ever wanted to know can be found here.
Re:Gphx card error
« Reply #2 on: August 31, 2003, 19:03 »
OK, I think I understood that.   :-\  What you ideally want is to set it to Region 0, then it should play most DVDs, although I can't understand anyone wanting to play a DVD on a PC, when they have a 'proper' DVD player in the lounge!   ::)
Re:Gphx card error
« Reply #3 on: August 31, 2003, 19:16 »
The message comes because of the Macrovision copy protection - if the graphics card cannot implement the macrovision then it's not supposed to allow playback of copy protected DVDs.
Media player will play DVDs when you have installed some commercial DVD playback software as it then has the necessary MPEG2 codec installed.
Offline lobo
    • http://www.burnleywood.com
Re:Gphx card error
« Reply #4 on: August 31, 2003, 19:44 »
Try a different player to play the DVDs with, I use BSplayer from here http://www.bsplay.com/works for me
Brian ;D
Homer   , The Odyssey, line 1
Re:Gphx card error
« Reply #5 on: August 31, 2003, 20:04 »
Thanks Brian!   :)
