Author Topic: Computer abreviations  (Read 10693 times)
Re:Computer abreviations
« Reply #15 on: September 01, 2003, 19:18 »
Or, I have another idea:
     What if those Techies make for us a list or a page in the forum in which they put the most common abreviations used, to let us understand what they are talking about when they solve certain problem.
      If possible, the abreviations and little explanation about each (as Sandra did a little before in her post).
      Michelle, if they don't do that for us, that means they don't want us to catch up with them. Also that means they are afraid of us.  Right?
« Reply #16 on: September 01, 2003, 19:23 »
You make the list Joudi and I will try my best to answer them as I would probably leave lots out that you wanted to know  :(
« Reply #17 on: September 01, 2003, 19:32 »
That's not an easy mission for me. It means that I must search in the forum posts every where to pick them up.
    If there is no other way, perhaps some others in the forum can help me. Everyone can get some and send them to Sandra. And by the time, perhaps you Sandra can add from time to time to that list.
    If there is any other better suggestion, may be someone can tell it to us.
                       Thanks Sandra
      But Sandra, Since when you are so kind?
                    I didn't know that before.
« Reply #18 on: September 01, 2003, 19:38 »
One which confused me when I first started posting on forums was "Mobo" as I had no idea what it referred to.  But mobo = motherboard.   ;D
« Reply #19 on: September 01, 2003, 19:40 »
Me too clive. It took certain time with me to discover it by myself.
« Reply #20 on: September 01, 2003, 21:53 »
Salut Joudi,je pense que je trouve que tu desire  :)
http://www.geocities.com/ikind_babel/babel/babel.html#A
Offline Michelle
    • Techieminx
« Reply #21 on: September 01, 2003, 22:13 »
I must say joudi it does sound a good idea but I can see how it would be difficult to put together.
 :D
My goodness, there are alot on that link !  :o  ;)
« Reply #22 on: September 01, 2003, 22:18 »
Well it tells you what the full names are Michelle but may not be of much use as knowing what RAM is doesnt necessarily help you to know what it does or how it does what it does but at least its a start I hope  :)
I have put a link to that site in the Useful Sites section and made it a "sticky" so it should be easier to find.
If anyone can find any better ones they can be added to it later,I will add the others that have been found to it now  :)
« Reply #23 on: September 01, 2003, 23:56 »
Thanks Sandra,
     Sorry for being late. I had my internet connection cut during more than 2 hours. I just got it back.
     Thanks for the link. I got another one:
   http://www.lemarsu.net/abrev/a-b.html
   and I thik what DJ1UK mentioned is very good, but unfortunately is too short. In fact, I'm searching like it:
   http://www.sgi.ethz.ch/abbrev_and_explan_en.html
     So, I'll continue searching on my side, and if someone finds like it or better that will be great.
                     Thanks
Offline Michelle
    • Techieminx
« Reply #24 on: September 02, 2003, 12:18 »
Thanks Sandra and Joudi  :)
That SGI site is good as it does have the explainations, not many on it though as you say.
Still its a start  :)
« Reply #25 on: September 08, 2003, 23:25 »
Like yourself Joudi, I have bother understanding all these intitials. I never knew that a PSU was power supply unit.  Why all these abbreviations need to be used I know not why. ???
This is quite a good site for newbies. :)
http://foldoc.doc.ic.ac.uk/foldoc/index.html
« Reply #26 on: September 09, 2003, 00:19 »
That's great Lona. It seems to me that this is what I am in need. I tried some abreviations and it worked nicely. I hope it works later for all what I need.
                  Thanks a lot.     :thanks:
« Reply #27 on: September 09, 2003, 00:26 »
I will add it to the main list in the useful sites thread then on your recommendation Joudi  :)
« Reply #28 on: September 09, 2003, 00:33 »
Thanks Sandra.  I knew you were going to do it and I was waiting, thinking that after a certain time if you missit I was going to mention that to you.
     Could be the best to put it as first link in that section.
                         Thanks Sandra.
« Reply #29 on: September 09, 2003, 00:53 »
Ok I have added it to the first one for you Joudi :doggie:
