Hey all!
Well, I finally took the plunge. Bought a new case (Thermaltake XaserIII), mainboard (DFI PS83-BC/BL), a P4 2.4ghz processor w/HTT, and new RAM to compliment(DDR400, set of 2 256mb DIMMs). =) Oh, ya, and a coolerMaster IHC-L71 CPU fan as well. Nice jump from my current P3 733mhz CPU, no?
So I get everything set up, happy as clam. Plug it all in and... nothing. I hear fans running (barely
![Grin ;D](http://www.pc-pals.com/smf/Smileys/Smileys/grin.gif)
) and I see the power LED come on, as well as the front panel LED. Yay. No monitor signal. Time to dive back into the case, check it out. I couldnt find anything that could popssibly be the problem. So I unplug all of my chips, and throw in my old PCI VooDoo3 (I was wondering if my GeForce2 had AGP 2x, which is not compatible with my mobo) and still nothing. So I turn it on to see if the mobo is getting proper power... it has its LEDs on, and the CPU fan is running (almost noislessly
) But alas, no signal.
I figure either I'm doing something wrong, OR either my mobo or CDU is dead. I checked the RAM already, its happy as clam. The only thing I can think of is the cases USB cables. The X3 comes with 2 USB ports on the top of the box, I plugged them into the mobo, and may not have done it right (the mobo had a set of pins that was 2 deep and about 5 wide, i looked at the PCI USB ports it came with and they were set up for that right away, while the box's USB cables ended in a one deep line of pins, that was 5 wide. I'm not sure if that can really hurt the system or not.... I hope not. =P Never experienced something like that before. Anyway, thanks in advance, everyone!
-Robert
