Author Topic: NTP (Time) Servers  (Read 1211 times)
Offline DJ
NTP (Time) Servers
« on: September 03, 2003, 16:21 »
Hi All,
As some of you are aware I am connected to broadband via a wireless home netork. I use a netgear DG824M wireless router and modem.
This sends a log to me each time an attack is suspected or when things go wrong, but I've noticed the time and date on these logs is wrong. Even when I log in to the router the time and date stated is wrong. The times and dates on all attached PCs are fine.
My question is this, I notice an option on the router to set the time zone, which I've set to GMT. I also notice that it has an option to enter an IP address of a NTP server.
So does anyone use or know of a free ntp server that would let me connect to keep the time and date up to date.
If you do can you post the IP address here for me.
Cheers  ;)
DJ
Re:NTP (Time) Servers
« Reply #1 on: September 03, 2003, 18:30 »
Try these DJ:-
ntp.demon.co.uk
ntp1.demon.co.uk
ntp2.demon.co.uk
time.windows.com
time.nist.gov
Offline DJ
« Reply #2 on: September 03, 2003, 19:25 »
:thanks: Adept problem solved.  ;)
DJ
