Author Topic: can someone help me  (Read 1140 times)
Offline GSS
    • artzone4u.com
can someone help me
« on: September 03, 2003, 17:52 »
can someone:help:me.what is the best way to get a lot of programmes from my pc to my laptop i can't fit it all on a cd rw the reason i ask this is because i keep going on my laptop a lot and goes to do something on it and not having the right programme on my laptop and i am now geting fed up having to go through my cds to find the programme i want by the time i find it i have not got enough time to do what i wanted to do
www.artzone4u.com
banner coming soon
Offline WhiteDevil
Re:can someone help me
« Reply #1 on: September 03, 2003, 18:08 »
whoa, punctuation please :brick:
well, you've actually answered your own question. You need the CDs to install the software onto your laptop... Why dont you set aside a few hours to install all the software you think you will need, then it will be there when you need it  ;D
dam Boyle
Owner, Director
www.Severn-Computers.com
Offline GSS
    • artzone4u.com
« Reply #2 on: September 03, 2003, 18:55 »
what can i sad :yoops:
i down a loaded a lot of kazaa lite and i have not got all of it on cd but you got a good point i could put the download from kazzaa and put it in that way then put the rest in from the cd
 ;Dthank you  ;D :yoops:
www.artzone4u.com
banner coming soon
« Reply #3 on: September 03, 2003, 18:55 »
Hi GSS,
     I have never done that before, but I can tell you a part of the answer, the others will add to my answer or give you better.
     If you have XP, you open "start" then "all programs" then you take the first in the list (in french it's called "accessoires") and then "system tools" there you have the option "assistant to transfer files and parameters".
     I can't lead you more than that. Hope my idea is correct.
     I know that there is a way to transfer by a special cable through usb. Is it the rest of the steps? I don't know.
Offline GSS
    • artzone4u.com
« Reply #4 on: September 03, 2003, 18:58 »
yes i got xp
thanks
i see what you mean are i need this to know how to use it
www.artzone4u.com
banner coming soon
« Reply #5 on: September 03, 2003, 19:01 »
The cable you are thinking of is USB bridge cable Joudi.
A better way is to set up an ethernet connected network or even a wireless one to the laptop.
Unfortunately none of these methods are suitable for transferring installed programs from one PC to another only the files from one PC to the other.
To install a program you need the CD or the download with the installer and exe files on it  :)
Offline GSS
    • artzone4u.com
« Reply #6 on: September 03, 2003, 19:04 »
i see ;D
ok i got the cd and the CD with the download with the installer and exe files on it just got to find time to do it
www.artzone4u.com
banner coming soon
Offline ketamininja
« Reply #7 on: September 04, 2003, 12:24 »
You cannot transfer INSTALLED PROGRAMS from one PC to another. Well, not unless you want to recreate ALL the registry entries in Windows Registry too. And with most programs, I wouldn't know how many reg entries have been made.
If you copy the directories across, the program will probably be unstable.
Offline GSS
    • artzone4u.com
« Reply #8 on: September 09, 2003, 10:13 »
thanks
i did it by cd rw in the end :)
www.artzone4u.com
banner coming soon
