November 28, 2024, 03:00
Technical Help & Discussion
Second user in W98 - Program List
Topic: Second user in W98 - Program List (Read 1246 times)
Thumbsup
Regular Member
September 04, 2003, 13:42 »
Hi there,
I have set up a second user in Windows 98, with full access to everything. But when I log on as this user, no programs appear in the Start - Programs list. Does anyone know how to make them known, possibly selectively ?
Thanks,
Andy
Michelle
Re:Second user in W98 - Program List
September 04, 2003, 14:09 »
Hi Andy K - I doubt its the same as ME but I'll tell you how I can do it on mine just incase it is the same.
Go to Control Panel - click on USERS and in there you can click on the user name and click change settings where you can add whatever you didn't add when you created the user.
Hope this helped if not, we'll have to wait for someone that knows 98. Which I'm sure won't take long.
September 04, 2003, 19:20 »
Sounds right Michelle.
I'm pretty sure ME is the same as 98 where user control is concerned.
You're becoming quite the techie Michelle
Michelle
September 04, 2003, 20:31 »
Thanks adept, I hope it helps.
Thumbsup
Regular Member
September 08, 2003, 16:38 »
Thanks Michelle. I knew where to go but not what to do, so now that one is solved too!
Off to my next problem now !
Andy
Michelle
September 08, 2003, 16:41 »
Andy
Yeah I know that feeling
and
You're welcome Andy
