Author Topic: Sound in sigs  (Read 5560 times)
Sound in sigs
« on: December 07, 2002, 12:25 »
Before my wife bans me from using my computer, does anyone know how to switch the sound off in the Christmas sigs?   ;D
Re:Sound in sigs
« Reply #1 on: December 07, 2002, 13:19 »
Dont roll over them Clive   :P
Or switch the speakers off while viewing the page  ;)
Re:Sound in sigs
« Reply #2 on: December 07, 2002, 13:27 »
I'm not usually that hot with these technical questions, but I have discovered that by pressing the 'Off' button on my monitors, it stops me jumping put of my skin whenever I inadvertantly mouseover on a sig.
An alternative method of making the sound produced by these sigs a little less noticeable involves playing Motorhead's Ace of Spades on repeat with the volume turned up full.
Hope this helps.   ;D
(Edit:  Whoops!  That'll teach me to answer the 'phone!)
Re:Sound in sigs
« Reply #3 on: December 07, 2002, 13:33 »
Miserable old gits could always remove their hearing aids CLIVE as well  ;)
[attachment deleted by admin]
Re:Sound in sigs
« Reply #4 on: December 07, 2002, 16:04 »
Thanks for all those encouraging remarks.   ;D  The speakers on my Adeptmobile are built into the monitor and it's already on "please do not disturb."  At least I've now found out how to turn it up if I need to.  ;D  Bah!  Humbug!  I enjoy being miserable over Christmas so stop spoiling my fun you lot!
Offline bat69
Re:Sound in sigs
« Reply #5 on: December 07, 2002, 20:23 »
Awww Clive you old tart ;)  :P   I think the sound sigs are brilliant, apart from giving me a hernia when I fell off the chair the first time I heard one :o ;)
Offline Corky
    • http://www.faceparty.com/corky_wales
Re:Sound in sigs
« Reply #6 on: December 08, 2002, 04:19 »
Or if you want to get reaaaaaaly complicated, use proper flash, create an action script that ties in with the PHP style coding of this forum and single out Clive in the script by selecting his name from the SQL DB.  Sounds tough, but Clive's old, sudden shocks could give him a heartattack...  ;D ;D ;D
img]http://www.raid-designs.co.uk/emote/corkypc.gif[/img]
Re:Sound in sigs
« Reply #7 on: December 08, 2002, 09:27 »
I think that's much too complicated for most of us, Corky - I'll just settle for the satisfaction of having a constantly annoying sig!   ;D ;D
Re:Sound in sigs
« Reply #8 on: December 08, 2002, 10:09 »
I'm being very careful where I put my pointer now Simon.   ;D
Re:Sound in sigs
« Reply #9 on: December 08, 2002, 10:18 »
Yaboo sucks!!  I've sorted it!  I went into sounds in control panel and clicked "mute".  I can now fearlessly put my pointer anywhere on the screen!   ;D  ;D  ;D  Sings to himself "Silent night, holy night, all is calm all is bright"   ;D
Re:Sound in sigs
« Reply #10 on: December 08, 2002, 10:21 »
Clive, you miserable bugger!!  ;D ;D
Won't that stop all your other sounds as well though?  Defeats the object of having speakers doesn't it?   ::) ;D ;D
Re:Sound in sigs
« Reply #11 on: December 08, 2002, 10:38 »
Yes it means I have no sound at all.   ;D  It's a small price to pay to avoid being banned.  ;D
Re:Sound in sigs
« Reply #12 on: December 08, 2002, 11:34 »
Well, sorry you don't like them, Clive.   >:D >:D
It's the brunette's fault - it was her idea!!  I think she should be banned for making our elderly members jump!   ;D ;D
Re:Sound in sigs
« Reply #13 on: December 08, 2002, 11:43 »
Just a thought, but isn't there some kind of command-line parameter for volume level that can be passed to the prog that saves the sound in your anim file?
Re:Sound in sigs
« Reply #14 on: December 08, 2002, 11:50 »
Err... I think the sound level is governed by the recording of the .wav file, if that's what you're referring to, Rodders.
On my PC, the sound on my sig is actually quieter than those on Sandra's and Barra's, but I don't think there's any way to adjust it from this end, once it's embedded in the .swf file.
I would have thought the easy solution would be to turn down the volume of your speakers if the sig sounds are found to be too loud.
