Author Topic: copying to cdrom  (Read 2458 times)
Offline tigerbee
copying to cdrom
« on: September 07, 2003, 20:02 »
:)  hi again people, i cant copy word files to cdrom; i keep gettin msg 'please insert disc into drive d' when I do, but i already put a disc there  ???
in fact i've never been able 2 copy to cd; i keep gettin same msg, give up, use floppy... :'(
compact disc using: cd-rw 700: re-writable compact disc
cdrom workin fine with all other cd's (eg. anti-virus, etc)
i bet itz a real simple thing eh?  :-\
thx any1 who can help  :)
tigerbee
(thx 2 all who helped me out wiv the cmmon32 probs  8) )
Re:copying to cdrom
« Reply #1 on: September 07, 2003, 20:08 »
Can you tell us which operating system and which cd-rw software you are using Tigerbee?
Offline tigerbee
Re:copying to cdrom
« Reply #2 on: September 07, 2003, 20:15 »
yup Adept, am using windows - soz wot u mean by cd-rw software  ??? it's a cd-rom disc; or do i hav to install something that i havent yet? i got a dvd rom drive btw...
cheers  8)
tigerbee
Re:copying to cdrom
« Reply #3 on: September 07, 2003, 20:26 »
Ah, well you cannot write to a cd unless you have a CD-Writer drive or a DVD-Writer than can also write CDs.
Offline Robotochan
Re:copying to cdrom
« Reply #4 on: September 07, 2003, 20:27 »
What Version of Windows? and what are you using to copy the files to CD? Nero etc.  ;D
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:copying to cdrom
« Reply #5 on: September 07, 2003, 20:33 »
I think Sean may have hit the nail on the head!   ;D
Offline tigerbee
Re:copying to cdrom
« Reply #6 on: September 07, 2003, 20:34 »
adept: ouch! u mean cd-rom drive needs 2 b a 'writer' drive? :(
robotchan: windows version ME; just goin into word, goin 2 file, clickin on 'send to' 'd: drive', then get msg 'insert disc into drive' etc
thx guys  8)
Re:copying to cdrom
« Reply #7 on: September 07, 2003, 20:52 »
If you're looking for a CD Writer, TigerBee, this one is worth considering, and is a reasonable price.  Check out the reviews also on that page.  :)
Re:copying to cdrom
« Reply #8 on: September 07, 2003, 20:55 »
The reason its asking you to insert a disc Tigerbee is because its a blank so it thinks that there isnt one in  :)
Offline tigerbee
Re:copying to cdrom
« Reply #9 on: September 07, 2003, 21:24 »
i assume sean is 'Adept'?  ;)
sandra, yep, disk is blank, but it acts as if no disc is in there; hence  >:(
shldn't it give a msg like: 'cannot copy files to the disc' rather than act as if no disc is there when there plainly is  ???
thx 4 info simon  8)
tigerbee
Re:copying to cdrom
« Reply #10 on: September 07, 2003, 21:46 »
No it has to say its "Empty " as it cant "see" a blank disc it just assumes you havent got one in or its a faulty disc so it gives you that error message :doggie:
Offline tigerbee
Re:copying to cdrom
« Reply #11 on: September 07, 2003, 21:58 »
oic  8)
me is not gr8 pc brain so i learn from u people  ;)
Re:copying to cdrom
« Reply #12 on: September 07, 2003, 22:03 »
Thats part of the reason that we are here to hopefully help and to teach a little and to enjoy ourselves of course  :)
