Author Topic: Command Line Utilities  (Read 1567 times)
« on: September 08, 2003, 18:33 »
I like this one  ;D.. Command
Enjoy  8)
Offline GSS
    • artzone4u.com
Re:Command Line Utilities
« Reply #1 on: September 08, 2003, 23:55 »
thanks for them ;D
www.artzone4u.com
banner coming soon
« Reply #2 on: September 09, 2003, 01:08 »
The command doesn't work on my PC but it's not so important for me. What is important is the list of those abreviations of commands which I asked someone before who did not help a lot.
               Thanks Hooky.
« Reply #3 on: September 09, 2003, 01:16 »
What do you mean when you say it doesnt work Joudi  ???
Have you opened the RUN box from the Start menu and typed CMD or Command in then clicked OK ?
« Reply #4 on: September 09, 2003, 01:19 »
another very useful command is:
winmsd
Which gives you a lot of information about your computer if runnig XP (and 2000 IIRC).
Its function is similar to the old MSD in dos.
« Reply #5 on: September 09, 2003, 02:23 »
Sorry Sandra, I misunderstood. I thought if we type "Command" or "CMD" there, it must give that list of command abreviations.
                           :soz:
      I still have a lot to learn.
