Author Topic: a different start up problem  (Read 944 times)
Offline Michelle
    • Techieminx
« on: September 09, 2003, 08:02 »
My next problem to ask you is ...sometimes my computer crashes (?) at start up, (I thought you'd had a long enough rest with my problems lol) it goes through all the checks and gets to my desktop all looks fine and stops. Then in the close program bit on cntl alt delete I see that it says MPR.EXE not responding. I think I've had this come up at other times too?   Oh and then I can't do anything so I have to turn off at mains or do what simon says and hold the start button in, then it does a scan disc and then I'm late for work!  :o
Am using M.E
Any idea's please guys ?
Re:a different start up problem
« Reply #1 on: September 09, 2003, 08:09 »
Here you go, Michelle... and here I go to work!!
http://support.microsoft.com/default.aspx?scid=kb;EN-US;178084
Offline Michelle
    • Techieminx
« Reply #2 on: September 09, 2003, 08:12 »
Thanks Simon I'll have a look later  :)
Offline Michelle
    • Techieminx
« Reply #3 on: September 09, 2003, 14:36 »
hmmm I've had a look.
Probably my selective start up wassit - which was causing a problem else where too.
Time to bugger it up then.  :D
Oh so technical  :-\
