HI Adept or any other clued up member,
I have got a USB query, on my Suntek PC case there are two front USB ports. Unfortunately the cable does not reach to my motherboard USB connector block [short by a couple of inches, and as such have left it unconnected. Anyway as I have ordered a digital camera, I was thinking of extending the cables to make the front USB ports usable, and I have a couple of questions.
The answer appears straight forward but I thought I best ask and make sure.
The JUSB2 pinheader on my MSI MOBO for connecting the USB ports cable to is labelled thus;
Pin Signal Pin Signal
1. USBPWR 2 USBPWR
3 USB2- 4 USB3-
5 USB2+ 6 USB3+
7 GND 8 GND
9 NC 10 USBOC
Now the cable that connects to the two USB ports on the front of the case are labelled thus;
There are two cables that end in a ten-pin connector at the USB ports end [pin 9 is NC]
At the Mobo end of the twin cables it is thus; one three pin connector labelled VCC: D2-:D2+: and a single connector labelled GND: The second cable is the same only D2-/D2+ are labelled D3-/D3+
Am I right in thinking the cable labelled VCC/D2-/D2+ connects to pins 1/3/5 with the GND connecting to pin 7. And the same for the other cable only on pins 2/4/6/8.
Well I am going to take the Grandson to see Santa now, and hope someone will have an answer for me on my return
![Kiss :-*](http://www.pc-pals.com/smf/Smileys/Smileys/kiss.gif)
Thanks
catch
