Author Topic: Internet Explorer 6  (Read 3809 times)
Internet Explorer 6
« on: September 13, 2003, 15:30 »
I can access websites from address bar no problem but if I try to click on websites from search engine explorer hangs and I have to ctr alt del and exit explorer.  I have tested with various search engines and receive the same result. If I copy and paste the addresses from the search engine into address bar I can access them, so it isn't a problem with the sites. I have uninstalled ex6 and re-installed but its just the same. This problem only happened since new hard drive was installed.
Re:Internet Explorer 6
« Reply #1 on: September 13, 2003, 16:08 »
Are you using a pop up stopper, Lona?  If so, try disabling it and see what happens.
« Reply #2 on: September 13, 2003, 18:59 »
I don't have a popup stopper running Simon. I have norton antivirus running, could it have a builtin popup stopper maybe.
« Reply #3 on: September 13, 2003, 19:01 »
Norton Firewall does, but not NAV, Lona.  I think even in Norton Firewall you have to enable it, but you haven't got that anymore have you?
How about trying a repair of IE, or a re-installation on top of itself?
« Reply #4 on: September 13, 2003, 19:27 »
A stopper wouldnt cause it to freeze when trying to open a link, its more likely to be an IE problem or setup option but shes repaired it and reinstalled it so I cant think at the moment what it could be apart from some kind of conflict  ???
« Reply #5 on: September 13, 2003, 19:56 »
It may be a problem with the sound that Windows plays when the URL is clicked.
I can't quite remember where it is kept in Windows Millennium (Control Panel|Sounds maybe?), but there is somewhere where you can change the sound associated with clicking the url.
« Reply #6 on: September 14, 2003, 01:22 »
Download Opera, Lona.
Only joking and it's so long since I used Internet Explorer that I can't remember what choices are in the options, but the first place I would look is for an option that opens a link in a new window.   I'm only guessing, but from what you say, it looks to me as if when you click on a link it tries to open a new window and is causing the browser to crash.
« Reply #7 on: September 14, 2003, 02:51 »
As you are telling something about the cause, it could be there Lona.
Are you sure that your hard drive is coreectly installed and connected?
« Reply #8 on: September 14, 2003, 03:59 »
That's what I am not sure of Joudi. I phoned the warrenty folk and they said if it's found to be a software problem then I will be charged for the call out. :(. I am hoping it is a faulty HD installation. :-\
« Reply #9 on: September 14, 2003, 09:03 »
I would be very surprised if it was a hard drive problem, if everything else is working OK, Lona.  As Dave said, it sounds like a setting in IE.  In Internet Options > Advanced, there is a setting "Reuse windows for launching shortcuts".  It's ticked on mine, and my IE works OK.  Clutching at straws really, but it might be worth unticking it, closing IE, then re-open IE and re-tick the same box.  You never know it might just work.  I can't find an option in IE to "open links in a new window", but I'm sure I've seen it somewhere before.   :-\
Edit: Have you seen this MS Knowledge Base article, Lona?
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q281679
Offline lobo
    • http://www.burnleywood.com
« Reply #10 on: September 14, 2003, 17:58 »
@Lona
Make sure that you have the latest version of IE Lona, I think its Ver 6-2800-1106 now that may help.  Or uninstall IE and reinstall it
Brian :niceday:
Homer   , The Odyssey, line 1
« Reply #11 on: September 14, 2003, 19:19 »
And will your on with it get shut of that bag of s**t called Windows Millen/98 bloat ware  ::)
« Reply #12 on: September 14, 2003, 20:20 »
I understand what you are saying, Simon and in the advanced settings the box is ticked. What I do not understand is, if I copy and past the website addy from the search engine into the address bar explorer does not freeze. I can then go to links from any website and it works ok.  It's only if I try to access a website directly from a search engine and that applies to any search engine.  I have tested it on google, altavista and dogpile.
« Reply #13 on: September 14, 2003, 20:22 »
@Lona
Brian :niceday:
Hi lobo
I have uninstalled explorer6 and re-installed it but the problem is still there. ???
« Reply #14 on: September 14, 2003, 20:46 »
I wasn't kidding about the sound thing Lona. A corrupted "click" sound file can crash IE.
Have a look in control panel | sounds. In the Windows Explorer section you will find an entry marked Start Navigation.
Click it and press the play button. If the sound plays OK, forget I mentioned it ::) Otherwise you need to click browse and choose a different sound file :)
