Author Topic: Webcreator 2  (Read 5154 times)
Re:Webcreator 2
« Reply #15 on: September 27, 2003, 23:20 »
Well, after some to-ing and fro-ing with various files, I finally got the correct file (I think).
Strangely, the entire page is made up of Javascript rather that HTML, but as far as I can see, it should open a mailto email form as expected.
I don't know much about Webcreator, but if it creates all of its web pages as Javasript, it's not going to be particularly compatible with a wide range of browsers.
I suggested to Clive that he may want to find a better tool to work with, such as CoffeeCup or even Microsoft FrontPage :-\
Re:Webcreator 2
« Reply #16 on: September 27, 2003, 23:32 »
So you think I should abandon Webcreator 2 in favour of something else?   :-\
Re:Webcreator 2
« Reply #17 on: September 27, 2003, 23:37 »
It may be easy to use, but the code it produces (from the evidence you've shown me at least) appears to be very poor.
It's rather like using Microsoft Word to create a website. It can be done and it's quite easy to do, but the code it produces is horrendous :o
