Author Topic: Outlook 2000 Autoresponders  (Read 2761 times)
Offline DJ
« on: September 19, 2003, 16:33 »
Hi all,
I'm going to be away for a few days next week and was wondering if there is anyway to set up an "autoresponder" / "out of office" in Outlook 2000.
I realise that these should be server based - so is there any little programs that do a similar job. My email addresses are with Force9 and IC24.
Basically I want a message to go to anyone who sends me a message to let them know that I'm away and I'll deal with their emails on return.
Any ideas?
Cheers  ;)
DJ
Re:Outlook 2000 Autoresponders
« Reply #1 on: September 19, 2003, 18:44 »
Hi DJ
The built-in "Out of office" feature in Outlook only works with Microsoft Exchange server I'm afraid.
I don't know of any software that does the same thing, but I bet someone on here does ;) :D
« Reply #2 on: September 19, 2003, 18:45 »
DJ Hi  :)
I had a quick look on my outlook 2000 but couldnt find anything, so in help it came up with the outlook site http://office.microsoft.com/home/office.aspx?assetid=FX01085793
Hope it helps
Hook  8) Star
Edited by Simon to fix link  :)  :P
« Reply #3 on: September 19, 2003, 18:48 »
Help.. what went wrong with the above link :(
« Reply #4 on: September 19, 2003, 18:51 »
Fixed it for you Hook.  You'd put a = instead of a ].   ;)
I think with all Mail Client auto responders, they only work if the machine is online and able to send mail.  If you want one that works while you're away, the only thing you can do is see if your mail provider has a webmail service, as these sometimes offer auto responders, but these days, probably not free.   :(
« Reply #5 on: September 19, 2003, 18:52 »
Youd added = and put the bracket in the wrong place Hooky, I sorted it for you now  :-*
« Reply #6 on: September 19, 2003, 18:54 »
Now now kids - don't fight. There's enough of Hookstar to go round :P
« Reply #7 on: September 19, 2003, 18:57 »
Cheers  ;)
Offline Michelle
    • Techieminx
« Reply #8 on: September 19, 2003, 19:01 »
Well I would have fixed it for you Hook :lol:
 ::)  ;D
« Reply #9 on: September 19, 2003, 19:49 »
Cheeky sod!!   :P :P ;D ;D
« Reply #10 on: September 19, 2003, 21:19 »
Sorry Simon we must have both been doing it at the same time and you had probably done it before I hit the submit button so it showed that I had edited it last  ::)
At least its done correctly now, whether you had made a mistake or not :P
« Reply #11 on: September 19, 2003, 22:08 »
:wahh:  ;D ;D
Offline DJ
« Reply #12 on: September 19, 2003, 23:19 »
Cheers for the tips guys, thought the PC would have to be on at all times.  :(
The ISPs haven't got an autoreponder feature, but they had suggested using outlook expreses mail rules and leaving the PC on all the time - I think not.
I'll just deal with the emails on my return.
Thanks anyway.  ;)
DJ
