Author Topic: Favorites Problem...  (Read 2105 times)
Offline Camstop
« on: September 23, 2003, 09:51 »
Hi guys...
Well i had a bit of a rough trot last night... ;)..And my pc was crashing left right and center...
Anywaysups..Now that it seems stable i find the my favorites have vanished from my fav button and i only have the links folder there (still ie6. Sorry simon  :-[ ;)) but when i look in my C drive favorites folder ..they're in there.. :-\
So how do i put them back on ie...because i can't liv without them...
Offline Serenity
Re:Favorites Problem...
« Reply #1 on: September 23, 2003, 10:05 »
Now dont panic Cammy  ::) One of our "techies" should be along shortly to assist you with your dilemma  ;D  :P
Offline Barra
« Reply #2 on: September 23, 2003, 10:36 »
Happened to me once and I solved it so it can't be difficult. Trouble is, I don't remember what I did :-[. It wouldn't be something simple like opening your foldeer in 'c',opening an IE window and dragging them across? It can only not work :)
« Reply #3 on: September 23, 2003, 10:39 »
Try going into View/Explorer Bar and make sure Favourites are ticked.  That usually does the trick for me.
Offline Camstop
« Reply #4 on: September 23, 2003, 10:40 »
Hehe thanks Ade..your a star...it worked a treat... ;)
Offline Barra
« Reply #5 on: September 23, 2003, 10:43 »
Life in the old dog yet! ;D
« Reply #6 on: September 23, 2003, 13:48 »
:mg: doesn't post for ages and then he comes in and does a "techie" :o
Nice to see you Ade :)
Offline Michelle
    • Techieminx
« Reply #7 on: September 23, 2003, 14:25 »
I was running here to your assistance but I see you are sorted  ;D  :P  8)
« Reply #8 on: September 23, 2003, 14:41 »
Now dont panic Cammy   One of our "techies" should be along shortly to assist you with your dilemma
       If you loose them next time Cammy, don't worry, don't you like the blondes to replace your favorites.    ;)    :blonde:
