Author Topic: system powers up but nothing else happens  (Read 1069 times)
Offline steve
« on: September 24, 2003, 23:45 »
please help
when i switch on my system everything powers up but nothing else happens
no bios screen
no bleeps
nothing
Re:system powers up but nothing else happens
« Reply #1 on: September 25, 2003, 00:02 »
Hi Steve, Welcome aboard  :)
Can you give some more details about the pc please?
The first thing to check is that the Clear CMOS jumper is set in the normal position not the clear it one or it will never go into bios or anywhere.
If thats set correctly then check that the memory is the correct type and that it is seated correctly.
Hope that this is of some help with the limited information that you have supplied so far  :-*
« Reply #2 on: September 25, 2003, 07:36 »
Hi Steve,
Is this a sudden fault with an existing system, or have you done some hardware modifications recently?  Also, it might be worth checking your CPU fan.  If it has stopped working, your CPU may have overheated, but let's hope not!  You could also check that your memory sticks are seated correctly, but if that was the problem, I think you would usually get some beeps.  It definitely sounds like a hardware problem, but as Sandra said, it would help us if you could provide some more information.
Offline steve
« Reply #3 on: September 25, 2003, 21:42 »
hello all
system details as follows
amd 1.33 cpu 266 fsb
abit kt7a-raib mobo
512 mb pc133 ram (have swopped with 256 & 128) all work in other machines
creative geforce 2 pro 64mb agp graphics card
removed mobo to insert ram so is seated correctly
cpu fan is working so is chip fan on mobo
was working untill psu failed
new atx 300watt psu fitted
this also works in other machine
all other cards and drives are disconected at present
thanks for all your help
steve ::)
« Reply #4 on: September 25, 2003, 22:07 »
Hi Steve :welcome:
It doesn't sound good I'm afraid :(
If you are sure that the PSU is OK, the only things left are the CPU and the motherboard itself.
I know you have checked the memory in another board, but have you tried switching on the PC without the memory fitted? This should at least give some beeps. If the board doesn't beep with the memory out, you need to test the CPU in another PC if you can. If it's working, the motherboard is shot :(
Did your original PSU fail nicely or did it go bang? :o
Offline steve
« Reply #5 on: September 25, 2003, 22:38 »
no the psu died peacefully in its sleep
one day worked next dead
was kicked out with full military honours
« Reply #6 on: September 27, 2003, 11:05 »
One thing thats worth trying is reseting the CMOS on the motherboard (I managed to get a lightening struck machine working this way). It is possible it was corrupted by the old power supply failing.
Failing that I'd guess as a motherboard fault :( or the new power supply not being up to the job - does it have the same ratings for +5 and 12V as the previous supply?
