Author Topic: Word to pdf  (Read 2103 times)
Word to pdf
« on: September 25, 2003, 09:03 »
I've been asked to send a Word document as a .pdf file.  Does anyone know how to do this?  I have Acrobat Reader 5.1 but that only appears to read files.   :'(
Re:Word to pdf
« Reply #1 on: September 25, 2003, 09:41 »
Don't know if this will help, Clive.  There's a demo version you may be able to use, if it's just a one off you want to convert.
http://www.bcltechnologies.com/document/products/easypdf/easypdf.htm
Re:Word to pdf
« Reply #2 on: September 25, 2003, 12:32 »
Clive .. try this one...... its freeeeeeeeeeware
PDF
This program can convert any text file into PDF file. The biggest advantage of this program is that it is freeware. You can choose rotation, pagesize, fonts and text size.
Hookstar
Re:Word to pdf
« Reply #3 on: September 25, 2003, 13:39 »
Wonderful!  Thanks Hook, I'll try it out.   ;D
Re:Word to pdf
« Reply #4 on: September 25, 2003, 19:15 »
There are a lot of online services that you can use if you don't want to convert very often.
FastPDF is one I picked randomly from Google :)
Re:Word to pdf
« Reply #5 on: September 25, 2003, 23:04 »
Thanks everyone.  Yet another triumph.   ;D
