Author Topic: Start-up menu problems  (Read 2199 times)
Offline martdon
« on: September 27, 2003, 16:32 »
I really need help! I use win 98, and my resources are at about 40%. when I use msconfig, and check selective, uncheck those items I want out, re-boot my computer, within a few seconds of restart they come back. There seems to be no save command for changes.
Don Martin
Re:Start-up menu problems
« Reply #1 on: September 27, 2003, 16:48 »
Hi Don and  :welcome:  One of our techies will answer your question very soon.
Offline martdon
« Reply #2 on: September 27, 2003, 16:53 »
Thank you very much!
Don
« Reply #3 on: September 27, 2003, 16:55 »
They are all away having their dinner I expect but I've left a message on Messenger to alert them.  I'm sure they will be able to help you when they return.
« Reply #4 on: September 27, 2003, 17:19 »
Hi martdon :welcome:
I just checked my Win98 machine. When you make changes to the settings in msconfig, it should ask if you wish to reboot as you press Apply or OK. AFAIK that's when it saves the changes.
« Reply #5 on: September 27, 2003, 17:22 »
I just found this Microsoft Knowledgebase article which may be some help :)
« Reply #6 on: September 27, 2003, 17:23 »
It has to be APPLY, if you only click OK then it wont save them on reboot Don  :)
« Reply #7 on: September 27, 2003, 17:27 »
When you press OK, Apply is implied Sandra. It is on my W98 anyway ;)
Offline Michelle
    • Techieminx
« Reply #8 on: September 27, 2003, 17:46 »
Just to confirm you can just press OK  ;)
Offline martdon
« Reply #9 on: September 27, 2003, 17:50 »
It still doesn't work!!
Don
Offline Michelle
    • Techieminx
« Reply #10 on: September 27, 2003, 18:07 »
Hi Don,
I'm sure the techies will be back to help you soon, but I assume that you are selecting "selective start up" on the general tab ? Although on mine which is ME it changes automatically I think, so you could just check that yours has.
« Reply #11 on: September 27, 2003, 18:07 »
Do you want to get rid of the startup items permanently or are you just trying them out to see if it makes a difference to your resources problem Don?
If you want rid of them permanently, the best way is to uninstall the software.
Another way is to edit the registry directly. This is effectively what msconfig should be doing. If you aren't experienced in registry editing, this can be dangerous though.
Offline martdon
« Reply #12 on: September 27, 2003, 18:20 »
Thank you, I am afraid of the registry, not enough experience. I just want to disable them, but be able to enable.
Don
« Reply #13 on: September 28, 2003, 09:48 »
First question is what are you trying to remove from the startup?
A lot of software is inter-related so that it will check it is intalled correctly and 'fix' any errors. By switching one program off you may be leaveing another dependant one enabled and so it will add the first one back in.
If you download and run Hijack this from
http://www.tomcoyote.org/hjt/
Select Scan and then post the log it creates on here - this will allow us to see what is trying to run.
but don't try and fix anything yet as it allows you to change the registry (which can cause all sorts of problems).
Offline martdon
« Reply #14 on: September 28, 2003, 13:41 »
I think I have thids problem thanks to you. This is a fantastic group People.
Don ;D
