July 03, 2024, 04:09
Technical Help & Discussion
Graphics card pci instead of agp
Topic: Graphics card pci instead of agp (Read 923 times)
Titanhenry
New Member
September 28, 2003, 17:11 »
Hello
Got a problem with my graphics card showing in device manager that my card is in a pci slot instead of agp which i have it in. I know that this wont be making the most out of my graphics card and was wandering if any one knows whats wrong
Re:Graphics card pci instead of agp
September 28, 2003, 18:06 »
Hi TitanHenry
AFAIK operating systems regard AGP as a "super-PCI" so your card may well be listed correctly.
If you run the Microsoft dxdiag utility (it should run from Start | Run) and go to the Display page, "AGP Texture Acceleration" should be enabled if your PC has detected AGP properly.
Titanhenry
New Member
September 29, 2003, 11:54 »
Yes i did what you said and it came up with that so does that means it working ok
September 29, 2003, 13:31 »
Quote from: Titanhenry on September 29, 2003, 11:54
Yup
