Author Topic: File Removal  (Read 1080 times)
Offline Dominic
File Removal
« on: September 28, 2003, 17:21 »
I have a problem removing a file, it's one i downloaded and remains on my desktop, says it may be in use by another application etc, so i rebooted, retryed and it's still there, any ideas?
Re:File Removal
« Reply #1 on: September 28, 2003, 17:55 »
Hi Dominic. Try booting in Safe Mode. This should allow you to remove the file from your desktop.
Offline Dominic
Re:File Removal
« Reply #2 on: September 28, 2003, 18:35 »
It's gone, i read on a site to rename the extension then remove, it worked, but why wouldn't it let me remove it in the first place?
Re:File Removal
« Reply #3 on: September 28, 2003, 18:37 »
I have no idea why that worked, but I will remember it for next time ;)
:thanks: for letting us know Dominic :)
