Author Topic: Adaware  (Read 2446 times)
Adaware
« on: September 30, 2003, 12:40 »
Hi folks just a small Question, when I start up adaware and look in what to search / delete, all my family are ticked in the various boxes and when it scans it only shows mine.
I log off me and log into the daughter/sons and there is loads to be deleted.. what gives.
Hookstar
Re:Adaware
« Reply #1 on: September 30, 2003, 15:54 »
Is everybody stumped on this one?
Re:Adaware
« Reply #2 on: September 30, 2003, 15:55 »
While I can't help with the multiple users problem Hook, I can recommend that you download Spyware Blaster.  It is a freeware program that stops spyware, tracking cookies etc. being installed in the first place.  Since I started to use it, AdAware hasn't found a single item on my system.  It can be downloaded at:
http://www.javacoolsoftware.com/spywareblaster.html
Re:Adaware
« Reply #3 on: September 30, 2003, 17:32 »
Have you tried running it when you are logged in as admin Hooky ?
I dont use it so not sure how it works but I would have thought that it should do all accounts if ran in admin :doggie:
Re:Adaware
« Reply #4 on: September 30, 2003, 18:47 »
Which version of Adaware are you using Hookstar?
I can't find any mention of my other users on version 6.181, running on XP ??? :-\
Re:Adaware
« Reply #5 on: September 30, 2003, 18:55 »
;D..Start the eveing off with a grin.
Yep am running V6 the very same Adept, also added a screen capture to show the said people as marked.
Hookstar  8)
Re:Adaware
« Reply #6 on: September 30, 2003, 18:59 »
What a houseful Hook!  My heart goes out to you.
Re:Adaware
« Reply #7 on: September 30, 2003, 19:01 »
Hookstar <<<<< Master  8)
Re:Adaware
« Reply #8 on: September 30, 2003, 19:04 »
I just hope Sandra doesn't add anything on to the end of "Master".  You know what she's like!!   :heehee:
Re:Adaware
« Reply #9 on: September 30, 2003, 19:07 »
Clive there is no doubt she will take this off topic as usual  ::)
Re:Adaware
« Reply #10 on: September 30, 2003, 19:16 »
Oh that! ::) :lol:
Adaware scans the registry for spyware, so I guess it cannot scan the registries of users which aren't logged in  :-\
Offline Michelle
    • Techieminx
Re:Adaware
« Reply #11 on: September 30, 2003, 19:19 »
I had to laugh at that....... well cos I got it :lol:
