Author Topic: Idle?  (Read 1537 times)
Offline Dominic
Idle?
« on: October 09, 2003, 23:34 »
Dunno what it is, i have cable, meant to be a continues connection, yet my msn signs out, at first i thought it was just msn, but when im on Mirc it d/c the same time as msn, and this is happening often, just wondering is there some sort of idle setting on Win xp pro that makes these progs end.
Re:Idle?
« Reply #1 on: October 09, 2003, 23:46 »
I dont think that its XP Dominic, mine does it occassionally saying that I have signed in at another location even though my no 2 PC isnt even switched on at the moment.
It hasnt done it for a few days until this evening and it has just done it twice now in less than 10 minutes.
I think its a fault with msn messenger itself, possibly a yet to be fixed bug in msn 6 as it seems to happen more frequently since I upgraded to msn 6  ???
Offline Michelle
    • Techieminx
Re:Idle?
« Reply #2 on: October 09, 2003, 23:50 »
meant to tell lona actually, there a few things we were putting down to moz, that were due to msn 6 problems .... like the messages about OS not opening attachments.
Offline Dominic
Re:Idle?
« Reply #3 on: October 10, 2003, 01:59 »
Mirc does it the same time, so it's not msn. And Sandra ya problem about other locations, one reason could be when u open Ms Outlook it opens the old msn as well .. and signs in auto, knocking of the newer msn.
Re:Idle?
« Reply #4 on: October 10, 2003, 02:06 »
No its not that as it does it even when I had nothing actually running apart from background stuff that always runs  :(
I was away from the pc and it had changed my status to away after 5 minutes or so.
When I came back here, I was about to open IE but before I had moved my mouse or clicked anything it signed me out  :(
I signed in again and logged onto Pals and within 10 minutes it signed me out again just before I replied to you  ???
Offline Dominic
Re:Idle?
« Reply #5 on: October 10, 2003, 08:30 »
Try this http://www.generaldiscussion.com/index.php?showtopic=3292 apperently the old msn runs in teh background, theres a link there that shows how to remove it.
