Author Topic: Quick Question  (Read 1123 times)
Offline Dominic
Quick Question
« on: October 12, 2003, 14:26 »
I'm about to foramt, (Win Xp) and i know as soon as i get my net connected i'll get either blast as nachi .. So what i wanna know is it ok to install a firewall before my internet? that way it should stop it. I just need to know if i install a firewall before internet that it won't mess up my internet when its installed. Im on 1meg NTL.
Re:Quick Question
« Reply #1 on: October 12, 2003, 14:29 »
Absolutely Dominic.
Don't even consider hooking up your Internet connection until you have up-to-date Firewall and Anti-Virus protection. Download them before you re-format and write them onto CD so you can install them immediately that XP is installed :)
Offline Dominic
Re:Quick Question
« Reply #2 on: October 12, 2003, 14:43 »
Ahh cool, i always installed these after my internet was connect, thought they may conflict my net connections or summin ::)
Re:Quick Question
« Reply #3 on: October 12, 2003, 15:15 »
Download and install the patch that stops XPs vulnerabilty to madblast too, prior to formatting then you can reinstall that before connecting to the net again Dominic. :doggie:
