Author Topic: Cache Problem  (Read 1362 times)
Cache Problem
« on: October 12, 2003, 15:03 »
I've been given a PC to try and fix for a friend of a friend ::)
It is a fairly modern Tiny PC (ugh!) which has had the motherboard and processor upgraded to an ASROCK K7VM2 and AMD 2400+.
The problem is that the machine starts Windows Millennium (double ugh!) and just as it goes into graphical mode, it corrupts the screen memory and crashes.
A quick run-through with PC-Check points to a problem with cache memory.
The question is; is it likely that there is a motherboard/processor fault or could it be that the pathetic 90w PSU in the Tiny case isn't giving the board enough power?
Re:Cache Problem
« Reply #1 on: October 12, 2003, 15:20 »
Is that a typo Adept  ???
I would have thought that was way to "TINY" to run anything above a 166  ::)
Re:Cache Problem
« Reply #2 on: October 12, 2003, 16:28 »
:heehee: nice one Sandra
Re:Cache Problem
« Reply #3 on: October 12, 2003, 17:25 »
No Sandra, that isn't a typo. 90w is what it says on the label. It is one of those mini PSU jobs.
That's why I asked the question! :P :P ::)
Re:Cache Problem
« Reply #4 on: October 12, 2003, 20:26 »
Well the little I know leads me to the conclusion that a 90W PSU wouldn't set the world alight.  Have you got another one you can try in it, Sean?
Re:Cache Problem
« Reply #5 on: October 13, 2003, 00:00 »
I've got a 180w PSU taken from a "Tiny" small tower case kicking about in the garage, if the lack of power is the problem Sean.  I can get you the model number if your interested, and it's yours if you are prepared to pay the postage.
Re:Cache Problem
« Reply #6 on: October 13, 2003, 07:26 »
:thanks: Tony,
As Simon suggested, I'll try a proper PSU as soon as I can. If that solves the problem, I'll suggest that a new case and PSU is bought. That Tiny case is 'orrible!
