Author Topic: I'll show you mine, if you show me yours  (Read 10342 times)
« on: December 12, 2002, 23:52 »
LOOK HERE
rodders was so impressed [and that's praise coming from him ladies] that he said I should show it on the forum  ;D
catch
Re:I'll show you mine, if you show me yours
« Reply #1 on: December 13, 2002, 00:31 »
The monitor on the left looks fine Catch but the central one and the one on the right seem to have wavy lines all over them,mine did that just before it packed up  ;D ;D ;D
« Reply #2 on: December 13, 2002, 00:36 »
well Sandra those two have Sony Triniton tubes in them and it's a build thingy, ask Adept. Mind you they should be straight horizontal lines, well they are on a weekend.
catch
« Reply #3 on: December 13, 2002, 18:17 »
Although somewhat lacking in extra monitors, this is what my
scruffy little corner of the Wibbly Wobbly Web looks like.
« Reply #4 on: December 13, 2002, 18:47 »
Are you hard of hearing Rodders  ???
Those speakers look like they may rattle a window or two  ;)
« Reply #5 on: December 13, 2002, 20:04 »
Trust rodders to be viewing something with a big horn on  ;D
I'm supprised you of all people missed that Sandra  >:D
catch
Offline bat69
« Reply #6 on: December 13, 2002, 20:11 »
Hopefully I'll soon get the memory for the new bat-machine, and then I get it all set up (no window in the case just yet ;))
Rodders, cool speakers  8)
Now I wonder if I can connect mine into my Marshall 4x12 cabinets  :o ::)
« Reply #7 on: December 13, 2002, 21:01 »
What's wrong with using a 'Mesa Boogie' either side of your monitor then, Bat?  Actually, there's no reason you couldn't use your cabs -- providing the neighbours are up for it!
Offline bat69
« Reply #8 on: December 14, 2002, 18:51 »
Ahhh Rodders, I'm patriotic and Marshall's are English.
Well with the new PC I can plug my guitar directly into it, output the signal from the PC to my 50W valve amp, take the output to my other 150W amp and power the speakers .... you should hear me from wherever you are  >:D
The neighbours won't know what blasted them into the next galaxy ;D
« Reply #9 on: December 14, 2002, 19:33 »
bat can you turn it down mate. i've just had to close my windows.
Offline Camstop
« Reply #10 on: December 15, 2002, 11:40 »
Mesa boogie valve amps are up there with the best of them, and the volume goes up to 13  >:D
marshall are cr@p and living on there name  :(  imho
very interested in putting my guitar through my pc. what do i need and how ?
and how do i get to play a part of an mp3 so that i don't have to listen to it all just practice one part, and can u do it with win-amp.
i would also like to add cuts of music to my dv camcorder clips.
thanks for any help
« Reply #11 on: December 15, 2002, 12:40 »
This nifty little utility, MP3 Trim, is the only way of performing a truly lossless edit on an MP3 that I know of, i.e. it doesn't convert your MP3 back into a .WAV before trimming it.  The downside, is that you'll need to guess the start and end times of the segment you want to keep, and then keep narrowing down those times until you reach perfection.  Thus it will be a bit hit-and-miss if you want to use it for 'chopping' purposes, but otherwise it's a startling bit of free kit which I thoroughly recommend.   ;)
« Reply #12 on: December 15, 2002, 12:48 »
Here is mine
[attachment deleted by admin]
« Reply #13 on: December 15, 2002, 12:52 »
They make you live in a wardrobe, Clive?   :o
Offline Serenity
« Reply #14 on: December 15, 2002, 12:59 »
Nice to see that you are making an effort to come "out of the closet" Clive  ;)  ;D
p.s.  nice furniture  ;)
