April 16, 2025, 10:45
Technical Help & Discussion
IE problems
Topic: IE problems (Read 2594 times)
Barra
Established Member
IE problems
October 14, 2003, 19:49 »
For the last couple of days I've been having problems with IE- and before you say anything Simon, no, I'll leave mozilla alone for now
- but only when I first try to open it,it opens then freezes. I have to use ctrl-alt-del to clear it. Then it's fine. It doesn't matter if it's opened with an email link,task bar icon or off desktop. I've got IE 5.5 and ME. Any ideas?
Tony
Loyal Member
Re:IE problems
October 14, 2003, 19:56 »
I would'nt know, I use................Mo.........Simon is it something you said
Barra why don't you update to IE:6 as M$ are not supporting IE:5.5 after December, so what you gonna do for your security updates
Barra
Established Member
Re:IE problems
October 14, 2003, 20:02 »
Last time I used IE6 I had problems with a few sites, can't remember if it was this one or the "other one", maybe both so I'm a bit wary of it
Re:IE problems
October 14, 2003, 20:18 »
I think you should do the upgrade Barra. You are going to have to do it at some point aren't you? I haven't heard of anyone having problems accessing the forum with IE6. Be brave. Sandra will hold your hand.
Re:IE problems
October 14, 2003, 20:20 »
Check your Home Page, Barra. Try it with the 'Use Blank' option. It may be trying to open something iffy whan you start IE. Just a thought.
Of course, you could always try Mo....
Tony
Loyal Member
Re:IE problems
October 14, 2003, 20:23 »
I had probs PC-Pals homepage, when I swopped from IE:5.5 to six IE:6, still have but it is only the images down the left hand side. Downloaded Macromedia Flash, but still no differance, but no matter I dont use it baring for one webpage.
Barra
Established Member
Re:IE problems
October 14, 2003, 21:14 »
mmmmm, 3 replies and one has problems with IE6. Doesn't inspire me
Re:IE problems
October 14, 2003, 21:53 »
Think I'm gonna sneeze... Mmm... mmmm... mmmo... mmmoozzz... mmmmozi... MmmozzzILLAA!!
Barra
Established Member
Re:IE problems
October 14, 2003, 22:05 »
Just proves mozilla is a nasty disease
Michelle
Re:IE problems
Reply #9 on:
October 14, 2003, 23:00 »
I have IE6 ME and Mozilla and I still get freezing!
Brrrrr tis cold
No truely I have quite a problem with freezing at the moment and it can happen on either IE or Moz
Barra
Established Member
Re:IE problems
Reply #10 on:
October 14, 2003, 23:21 »
mmmmmm, 50-50 chance of it working then
Tony
Loyal Member
Re:IE problems
Reply #11 on:
October 14, 2003, 23:27 »
it's obviously an ME problem this freezing mularky, ditch the bitch I say, and walk into the light with W2K or it's variant XP.
Michelle
Re:IE problems
Reply #12 on:
October 14, 2003, 23:37 »
mmmm could be, but why would it just start freezing now, more than ever?
I thought that it must be something else on our computers that ME doesn't like?
IE problems
