Author Topic: Windows OS Breaking Point  (Read 5955 times)
« on: October 16, 2003, 06:12 »
I saw a post by a member asking about how best to protect a windows box from being used or tampered with while the owner was away. I red the post and thought the question shouldn't be how to protect but instead how to break into. In creating this topic i think it would enlighten everyone to the various ways in which a pc could broken into and way to prevent it.
to start this off, and not look like im pumping people for information for diabolical purposes i found a way to get around xp passwords about a year ago. Just restart the machine and press F8 when the diagnostic options are presented go into safe mode. if the installer of the os was lazy (like most) and didn't put a admin password enter the admin account and setup your own user accout. In safe mode you can access any and all of the other accounts making your attempt successful.
I haven't found a way to lock a windows machine from someone slaving it. But i have run into software that works with the bios. If the drive is put into another machine or it is made as a slave on its default box it has to have a password to access. It was a churches machine and the drive was going bad. i ghosted it and stuck the new drive in place. It did interest me though.
Offline ketamininja
Re:Windows OS Breaking Point
« Reply #1 on: October 18, 2003, 12:23 »
In windows xp, you can load up in NORMAL mode, press CTRL-ALT-DEL twice at the logon screen, and that will allow you to type in the "Administrator" name, with no password to access normally.
XP, being based on NT technology is quite secure - you can lock folders etc etc... which cannot be done on a 98 machine of course.
I have a special piece of software (Linux based) that boots from CD. It checks NT based security, and will check the SAM for passwords etc. The software will then let you clear individual passwords, or ever create a different password.
The only problem is, if you CLEAR, it also clears any stored internet/msn username and passwords.
There is no way to prevent this boot disk from gaining access to the SAM, unless you lock the pc box where no one can get physical access.
« Reply #2 on: October 18, 2003, 17:39 »
Just a word of caution as this thread progresses - please bear in mind we cannot discuss hacking on this forum.
Thanks folks!   :)
« Reply #3 on: October 18, 2003, 18:35 »
That kinda ticks me off. I think education on these security flaws is the best way to be aware and prevention. Unless you want something like what we've said happen to you.
When i was in high school someone used the method i mentioned to break into my pc. It took me two weeks to figure out how he did it. I finally had to format the machine and put in a new admin password because they had locked me out of my own pc. Its crap like this people should be aware of, so the same situation doesn't repeat itself.
http://home.planet.nl/~faase009/Ha_hacker.html
If you read this you'll notice we are technical crackers. Even though im doing this to expose flaws that would potentially give me and others problems it is still cracking. Guess your right, maybe we should delete this topic for the safty of everyone. ;)
« Reply #4 on: October 18, 2003, 19:20 »
I'm sure that everyone realises that we have to err on the side of caution and that very mention of the word "hack" gives our hosts palpitations.  The members of the forum fully appreciate where you are coming from Bob and greatly appreciate your input.   Just be careful with the "H" word so that we can all sleep soundly in our beds at night.   :lol:
« Reply #5 on: October 18, 2003, 19:55 »
Is this not the same as....
Go
START->RUN and type control userpasswords2
« Reply #6 on: October 19, 2003, 13:08 »
I'm with you Bob on this one [just to put the cat amongst the pigeons]  ::)
Education is better than falling victim due to lack of it. For instance, it would be like rollocking those who expose ways of circumnavigating so called airport security, which would enable weapons/potential weapons to be smuggled aboard aircraft.
It is only the public boycotting products due to their exposed security flaws that pressures providers of such products to up their game.
« Reply #7 on: October 19, 2003, 17:08 »
I fully understand where Bob is coming from.  All I'm asking is please don't let this thread turn into a discussion about ways to hack Windows.  I wasn't 'rollocking' anyone, but we have to be aware of our hosts rules.  Sorry if I didn't make myself clear.
« Reply #8 on: October 19, 2003, 21:24 »
i agree there should be no talk of hacking on this thread to protect the safty of PC Pals Forum. I guess we got this off on the wrong foot. Anyone know anyother cracks for windows that we should be aware of.
I knew linux had bootable software for diagnostic purposes but i didn't know it had security checker for NTFS.  ???
« Reply #9 on: October 19, 2003, 23:47 »
Simon...Bro  ;)
I didn't mean to infer or imply [ not sure which one I should be using] that you were "rollicking"  Bob.
I mean would I  ::) ;)
« Reply #10 on: October 19, 2003, 23:53 »
alright everyone, don't bust a nut all over your monitors. :-* I wasn't being rollicked, so don't worry. It was a simple misunderstanding thats been cleared up.  :D
« Reply #11 on: October 20, 2003, 00:11 »
Don't worry Bob, me and Simon wont bust our nuts, we just wind each other up now and again, it's a sign of endearment you see.   :)
« Reply #12 on: October 20, 2003, 00:12 »
Not with W2K Pro you carn't  ;D
« Reply #13 on: October 20, 2003, 07:49 »
Tony, did I tell you I installed W2K Pro on one of these new builds?  Well, it all went tits up when I tried to get the updates, It wouldn't let me install Norton AV or Firewall without getting the patches first and I kept getting infected with the Welchia worm, before I could get the patch!  Catch 22, you might say.   ;)
Anyway, eventually the hamster woke up in the wheel, and I got the patch onto a floppy using my own machine, installed it on the W2K machine, and then managed to get SP4, and all the other updates, however, each time I booted up, I was getting a 'program error' box.  Just the box, with a red X in it, but no message to say what was wrong!  Pretty useful, huh?
It was time to kill or cure, and as I didn't know what to cure, W2K Pro went to an early grave, and XP was installed with no problems.
« Reply #14 on: October 20, 2003, 08:39 »
Funny that Simon,
I've never been infected with a virus, when I have installed new or reformated and installed many many times with W2K Pro.
I always do install, then put all the security progs on first, Zone Alarm being the first.  Then I go nowhere but MS update. First thing I then do is SP4, then all other patches. Then Norton updates, and only then do I, go else where on the Web, or set up email accounts, or install any programs.
You must be working in an unsterile enviroment.  ::)
