Author Topic: 'Links' folder in IE6 Favorites  (Read 4788 times)
« on: December 14, 2002, 10:55 »
Just a curiosity, this one, but I deleted the 'Links' folder from my IE6 Favorites drop down menu, as I didn't use anything in it, however, after a while it keeps reappearing!  Any ideas on how I can make it disappear for good?  Not that it's doing any harm - it's just irritating, because I'm supposed to be in charge!
Re:'Links' folder in IE6 Favorites
« Reply #1 on: December 14, 2002, 10:57 »
Yes, I'd be interested in a solution to this too.
I find it irritating, but not irritating enough to do something about it  ::) ;D ;D
Offline bat69
« Reply #2 on: December 14, 2002, 18:45 »
I might find out soon when I get the memory for my new PC and get XP up an running ... its just the sort of thing I like doing ... I'm not a big fan of IE or Microtwaddle being in charge >:D
Offline Barra
« Reply #3 on: December 14, 2002, 23:58 »
Of course you could put things in it Simon that would be useful. That would solve your problem ;D
« Reply #4 on: December 15, 2002, 00:11 »
I use the links feature on IE6 a lot. If I want to add a site a just drag it over to the links on the toolbar then I can always find it again. I keep all my special websites in the links and I don't let the family use it. They have to make do with favourites.
« Reply #5 on: December 15, 2002, 00:23 »
Youve got the wrong end of the stick Lona.Its the LINKS folder in the FAVOURITES that we are trying to get rid of,not the toolbar one  ;)
« Reply #6 on: December 15, 2002, 00:30 »
Sorry Simon, I never noticed that folder as I never go into favourites. That's for the more menial users of this PC ;D
I looked in favourites, Sandra and it is just a copy of the links in the toolbar
« Reply #7 on: December 15, 2002, 11:29 »
Aren't they the same thing Sandra ???
Anything you put in the Links folder appears on the Links toolbar and vice versa.
« Reply #8 on: December 15, 2002, 15:09 »
It looks like they are Adept.I never use the links folder or the one on the toolbar as I dont like too much clutter on my toolbars.I just try and organise my favourites into folders such as all forums I visit in one and financial dealings in another etc. :-*
« Reply #9 on: December 15, 2002, 20:25 »
Found this article by mistake and thought I would post it  ;D
according to the Microsoft Knowledge Base, you can't "move, delete, or rename the Links folder on the Favorites menu." For more information, check out this link: http://support.microsoft.com/support/kb/articles/Q179/5/99.ASP However, you CAN hide it, as the Knowledge Base notes. Here's how: Select Favorites on the toolbar. Right-click the Links folder and choose Properties from the pop-up menu that appears. Select the Hidden box. Click OK to close the Properties dialog box.
Just a thought  Hook
« Reply #10 on: December 15, 2002, 22:01 »
Nice one Hook! 8)
A bit of lateral thinking works wonders doesn't it? Don't delete it - hide it  ;) I'll remember that.
« Reply #11 on: December 23, 2002, 13:04 »
Just to follow on from Simons little query, as you all know by now Im running XP with IE6.
Wellllll I set up the links bar at the top of the screen with all my faves and lock the tool bars and then log out!!!!!!!!! but when I log back in it has changed to a different setting ho hum.. like Simon ;D doesnt look like Im the master anymore lol.
Hook 8)
« Reply #12 on: December 23, 2002, 18:17 »
Well, even after trying to hide the links folder, rather than deleting it, the bloody thing still keeps reappearing!  I think it's purpose in life must be to wind up the user!   >:( ;D
« Reply #13 on: December 24, 2002, 21:05 »
Tell you what to do, Simon. Rename it "Simon", it won't get rid of it but at least you will see your name on IE6 ;)
« Reply #14 on: December 24, 2002, 21:36 »
Great idea Lona!  Do you think Uncle Bill will adopt it for IE7?   :D :D
