Author Topic: Which Program to choose  (Read 1717 times)
Offline Serenity
« on: October 18, 2003, 10:44 »
Hi Guys   :-*
I need a good program for my pictures.  I used to have paint shop pro 5 and it worked a treat but with all my recent PC problems I lost the program when I transferred to XP Pro  :-[
Can you recommend a good alternative program as I am unable to resize any of my pics to post on here  :'(
Re:Which Program to choose
« Reply #1 on: October 18, 2003, 10:53 »
I use Paint Shop Pro 7 but I think there is a later version available now.
Offline Robotochan
« Reply #2 on: October 18, 2003, 10:59 »
Yup your right clive version 8.0 is out now 2x the size of the 7 trial so I'm sticking wiht 7  ;D
b]Oxymoron: [/b]
Example:
Microsoft Works
« Reply #3 on: October 18, 2003, 14:11 »
Hi Sen,
I use Adobe Elements V1, Simon has V2, they are stripped down versions  of Abobe Photoshop, which is suposed to be "The" profesionals choice, I believe that is at V7.
"Cough" a mutual "freind"  sent me V7 but I find  Elements is really all I need, because that is a powerfull piece of software in it's own right.
« Reply #4 on: October 18, 2003, 17:44 »
I have Paint Shop Pro 8 now, having just upgraded from 7.  Apart from a newer looking layout, I haven't found much difference yet, but yes either that, or Adobe Elements will do the job, Bev.
Offline Serenity
« Reply #5 on: October 18, 2003, 18:27 »
Thanks for replies guys, I will make my mind up this weekend  :-*  :-*
« Reply #6 on: October 18, 2003, 19:09 »
That will be quite an achievement for a woman Serenity.   ;D
Offline Serenity
« Reply #7 on: October 18, 2003, 19:14 »
Clive I am quite capable of making an informed   decision on any subject thankyou  ::)  :P  its the idiots around me that I have a problem with  ;D
« Reply #8 on: October 18, 2003, 19:45 »
She has friends in the know Clive  ;)
« Reply #9 on: October 18, 2003, 19:49 »
Serenity, you could always buy the December issue (out now)of the Microsoft Windows mag and get the free disk with Essential Digital creativity toolkit and free ware.
Hook  8) star
Offline Serenity
« Reply #10 on: October 18, 2003, 19:53 »
Ty Hook for the advice  :) but I think I can get it  free  ;)   (shhh nobody heard that did they  :-X)
« Reply #11 on: October 18, 2003, 20:00 »
How do you know I'm not a whistle blower..  :-\ working for Uncle Billy Gate$
« Reply #12 on: October 20, 2003, 00:21 »
Well if you are Hooky, I reckon you could be in for a good "spanking" of Sen.................[if your lucky] ;D
