Hi all.
Here's the deal:
XP PC was infected with Blaster and Welchia.
This has been repaired, with patch added.
System will connect to the internet via
dialup, but "Page cannot be displayed" for all web pages, and ping IP and "request timed out". Ping hostname and "could not find host".
I have used the XP winsock fixer program, but this solves nothing.
IN MY IP SETTINGS at the cmd prompt it shows everything normal... except DHCP ENABLED = NO.
Now this PC has a NIC too. Which DHCP settings enabled, it cannot get a correct IP address from the internal network. It uses its own Windows address range.
If I manually assign the NIC, the PC can all of a sudden ping INTERNAL LAN PC's but is still behaving as above - no web pages, no ping outside lan.
HELP! and thanks!
