April 19, 2025, 09:26
Technical Help & Discussion
blank screen
Topic: blank screen (Read 929 times)
lagerlass
New Member
blank screen
October 22, 2003, 20:04 »
hi there, hope someone can help,dad having probs when booting up pc,get the first screen, beeps once and goes black - running windows xp, anyone got any ideas
thanks
Re:blank screen
October 22, 2003, 20:32 »
Does it get past the BIOS screen Lagerlass (counting the memory, telling you about the hardware etc)?
It sounds to me as if, either the hard drive has failed or the BIOS settings for the drive have been changed causing the drive to be unreadable.
lagerlass
New Member
Re:blank screen
October 22, 2003, 21:12 »
hi,gets to that screen where does mem check etc but then it beeps and goes blank
Re:blank screen
October 22, 2003, 21:14 »
OK, you'll need to count the beeps. There should be one long beep and a number of short ones.
lagerlass
New Member
Re:blank screen
October 24, 2003, 08:16 »
hi, there is just the one beep and then nothing, no sound and a blank screen
Sandra
Ultimate Member
Re:blank screen
October 24, 2003, 11:49 »
Has this only just started happening ?
Will it start in safe mode and display the screen or does it not even get to that stage ?
blank screen
