Author Topic: startup problems!!!  (Read 1494 times)
Offline erni
startup problems!!!
« on: October 23, 2003, 10:01 »
Hi.
I have a pc with a MCI motherboard and an AMD Duron 800. I recently installed a new cooler. Eversince I have had problems at startup. The computer sounds like itīs running but the display is blank. At one time the computer started with a message about probable hardware change. Then windows started but pretty soon the computer frooze. Could something be loose on the motherboard? Thankfull for any ideas... Erik
Offline ketamininja
Re:startup problems!!!
« Reply #1 on: October 23, 2003, 10:48 »
I presume that the cooler was installed correctly? Did you attach the power to the CPU fan connector? Sometimes boards will check this connector to see if the fan is spinning. If its not, the PC wont start because it thinks the cpu will get damaged. Make sure its not attached to the SYSTEM FAN CONNECTOR.
Does the pc give you any beeps?
The best way to go about finding the problem is like so:
Clear the BIOS.
Check the PC to see if it starts.
Strip the pc down to CPU & Cooler, Memory, and GRAPHICS card.
(Remove all IDE cables from the board and all other cards).
Remove the graphics.
Check the PC gives you beeps.
Put the graphics back in, remove memory.
Try that, then get back to us when you know which optioins above were working etc.
Offline erni
« Reply #2 on: October 23, 2003, 11:29 »
The cooler is connected to the cpu fan connector and it seems to run fine. The computer gives me one beep as it is and it seems to come from the hard drive. Iīll try the tips and get back.Tanks
Offline erni
« Reply #3 on: October 23, 2003, 12:31 »
Ok, Iīve tried the sugestions.
When CMOS jumper is set to clear data mode the pc doesnīt start at all. None of the other steps made any difference. I get one beep (not from the hard drive then) but nothing on the screen.
« Reply #4 on: October 23, 2003, 13:14 »
The jumper must be set back to the normal run position after you have cleared it for it to start up again  :-*
« Reply #5 on: October 23, 2003, 13:16 »
Hi erni :welcome:
Did you remove the CPU when fitting the new cooler? It doesn't sound like the cpu is correctly seated in the socket or possibly a pin may be damaged  :-\
Offline erni
« Reply #6 on: October 23, 2003, 13:55 »
Thanks for all the tips! My problem has taken a new turn: After removing the cooler and wiping the cpu clean the pc starts again. But before windows starts I get the message "Warning. CPU has changed. Set new ratio in Bios"
Offline Michelle
    • Techieminx
« Reply #7 on: October 23, 2003, 14:27 »
Not techie but bored :)  so found this .......... dunno if might help..... If system starts, BIOS settings were wrong.  Reset BIOS properly for CPU.
http://www.7volts.com/troubleshooting.htm
Page looks something like what you are talking about,  think you would know more than me on that.
Edit:Disclaimer  :o  ;D
Offline Serenity
« Reply #8 on: October 23, 2003, 14:33 »
Not techie either Erni just thought Id say  :wave:  :welcome:   I have more expertise in other areas  ;D
Offline Michelle
    • Techieminx
« Reply #9 on: October 23, 2003, 14:35 »
oh excuse me ......... my manners are bad  ::)
Welcome from me too  ;D
The techies will get out of their beds soon  ;D
Offline erni
« Reply #10 on: October 23, 2003, 14:58 »
Thank you for welcoming me to what seems like a great forum.  :)The pc seems to be working fine again. I simply reset my BIOS ( I guess my cpu was out of place which caused the settings to change when I cleared BIOS...something like that)Thanks again.
« Reply #11 on: October 23, 2003, 15:05 »
Blondes  ::)
Offline Michelle
    • Techieminx
« Reply #12 on: October 23, 2003, 15:15 »
Thats good erni  ;D
Hookie, yes you are  ;D
Offline Serenity
« Reply #13 on: October 23, 2003, 15:18 »
Blondes  ::)
Yes, thankyou for your input Hookstar  ::) meanwhile  back at the ranch  ;D
« Reply #14 on: October 23, 2003, 18:13 »
Welcome Erni!  Glad your problem is solved, but that doesn't mean you can escape from us!   ;D
Hope to see you about again soon.   ;) :)
