April 16, 2025, 09:49
Technical Help & Discussion
Tapisrv
Topic: Tapisrv (Read 1617 times)
Barra
Established Member
Tapisrv
October 24, 2003, 18:39 »
Not sure if this is in the right place or not, but I'm sure some eagle-eyed mod will sort it if it is.
Sometimes when I disconnect from my DSL I get the message "Tapisrv has caused en error in RPCRT4.DLL. Tapisrv will now close". The 2 monitor icon remains in taskbar by the clock. The only way to get rid of it is to reboot. This is happening about 7 out of 10 times.
Any ideas folks?
Dack
Established Member
Re:Tapisrv
October 24, 2003, 21:23 »
Just wondering what OS you are running - there are a few mentions of a similar problem.
e.g.
http://www.bearcy.com/adsl-win2k.html
Basically any info like OS, Modem type, when it started would be useful as there doesn't seem to be a generic problem for those symptoms as such.
Re:Tapisrv
October 24, 2003, 21:34 »
I had a look around earlier Dack, and it seems to be a problem with Windows 98. I have seen suggestions that one of the Microsoft patches may cure it so it may be worth checking to see if any updates are available Barra.
Barra
Established Member
Re:Tapisrv
October 24, 2003, 21:42 »
Hi Dack and Clive. I'm on ME and NO I'm noy changing to XP
I'm up to date with all patches Clive. This only started happening when I had to reinstall ME recently. Keep the ideas coming folks!
Dack
Established Member
Re:Tapisrv
October 25, 2003, 09:09 »
Looks like it's 'one of those things' that happens with ME
http://www.freedom2support.net/forums/showthread.php?
s=bd2bb8b969884af82112225c20c1e60f&threadid=1026&highlight=tapisrv+rpcrt4
Solution there seems to be - Change OS
* Simon edited link for users of superior broswers.
Michelle
Re:Tapisrv
October 25, 2003, 11:02 »
Thats one of the few problems I haven't had with ME then.
I've not seen that one Barra, I do get alot of messages about other DLL's though.
Tapisrv
