Author Topic: Win ME - REGENV32.EXE  (Read 6315 times)
« on: October 25, 2003, 21:51 »
ME really is a complete bag of poo, isn't it!  My soon-to-be-ex missus has decided that she's going to be the new owner of my laptop, so I did a full clean reinstall of ME from the bootable install CD, which has a Ghost file containing ME and the drivers.
Not long after I'd downloaded the ton of updates required to make ME usable and then adding a number of security apps, I was hit with a BSOD right out of the blue.  On re-booting and going through the CheckDisk rigmarole, REGENV32.EXE was found to have corrupted.  The original file is around 72k, while the repaired file is 60k.
This is apparently a well-documented problem, but why doesn't Microsoft provide a downloadable replacement, for goodness sake?
Oh yes...  I did extract a copy from the CAB in windows/options, but found that corrupted, too!
Anyone got an original?  PM me.  8)
Re:Win ME - REGENV32.EXE
« Reply #1 on: October 25, 2003, 23:35 »
Give me a few minutes, Rodders, and I will see what I can do. My WinMe disc is not a complete copy of WinMe but HP's restore disc. I will search for that file and send it to you ASAP. :D
« Reply #2 on: October 25, 2003, 23:46 »
Found File and it's on it's way to you. Let me know if it works. :)
« Reply #3 on: October 26, 2003, 00:20 »
Nothing yet!  I'm just wondering whether my ISP blocks executable attachments.   ???
Edit: Smelling pistakes.
« Reply #4 on: October 26, 2003, 00:23 »
I sent it to your pals addy, Rodders. If you PM me a different addy, I will try again. :)
« Reply #5 on: October 26, 2003, 00:27 »
Sorry, Rodders, the email just came back to me and said I will have to zip the file and then send it because it is an exe file. Hang on there :)
« Reply #6 on: October 26, 2003, 00:49 »
Result!  Cheers, Lona!
Offline Barra
« Reply #7 on: October 26, 2003, 09:46 »
I've just checked my REGENV32.EXE and mine is only 60k but I've not had the problem you have had Rodders. What exactly is it for?
« Reply #8 on: October 26, 2003, 10:36 »
It seems to be a handler for Environment Variables, and writes to the registry whenever ME is shut down.  There's a lot of related stuff that can be found on Google when searching by the filename.
« Reply #9 on: October 26, 2003, 10:39 »
Lona:
I've just checked out the Zip you sent me, and found you've included the wrong file.  Could you have another crack at it, please?
« Reply #10 on: October 26, 2003, 20:09 »
going back to your original point rodders, ME really is a pile of crap, more unstable than iraq. get a bsod every day without fail.  having said that at least you dont have to ask bill gates's permission to make a few hardware changes  :-X
« Reply #11 on: October 26, 2003, 20:17 »
Hmmm...  Good point, Dave!
« Reply #12 on: October 26, 2003, 20:20 »
i've sent a zipped copy of it to your pcpals addy
« Reply #13 on: October 26, 2003, 20:32 »
Cheers Dave!  I was kind of hoping for the 72k version, though.  I don't suppose you could have a butchers in Cab 17(?) of your Win ME disc for the original?   ;)
« Reply #14 on: October 26, 2003, 21:28 »
Sorry Rodders if it was the wrong file but I sent you the file you asked for which was REGENV32.exe. Is it a different file that you need?
