Author Topic: is there a way  (Read 3218 times)
Offline GSS
    • artzone4u.com
is there a way
« on: October 31, 2003, 17:04 »
is there a way i can put a Counter in my sig in tvchat that counts up every time i post or reply
if i put this i the wrong part can someone put it in the right part :)
www.artzone4u.com
banner coming soon
Re:is there a way
« Reply #1 on: October 31, 2003, 17:08 »
Isn't that the same as a post count, GSS?  Don't you already have one of those?   :-\
Re:is there a way
« Reply #2 on: October 31, 2003, 17:21 »
You could make another button using Swish or similar that linked to an url where your post counter was on the forum possibly GSS.
That way if you hovered or if and it had the "Go to xxxxURL" command in that would display it I think.
No doubt DJ will be along soon with a quicker and easier solution again  ;)
Offline GSS
    • artzone4u.com
Re:is there a way
« Reply #3 on: October 31, 2003, 17:30 »
sandra you are right what you said but why i neen the seperater counter for is so i can reset the post count once a mouth
i also only need it to count the post and reply's i post
www.artzone4u.com
banner coming soon
Re:is there a way
« Reply #4 on: October 31, 2003, 17:37 »
If you want to do that you would have to have a second post counter on your site to link to and reset that one only.
There are a few different hit counters available for use on personal webspace but whether there are any post counters available other than the ones that come with the forum software I am unsure  ???
Offline GSS
    • artzone4u.com
Re:is there a way
« Reply #5 on: October 31, 2003, 17:48 »
ok its not for tvchat but this for a forum that uses the same forum supplier that tvchat uses i pu tvchat has it was easier :)
this this what it need for http://s2.invisionfree.com/Christian_Revivals/index.php?showtopic=110
www.artzone4u.com
banner coming soon
Offline DJ
Re:is there a way
« Reply #6 on: October 31, 2003, 22:48 »
:lol: Nope I haven't got a clue on this at all. All I can suggest is whats already been said  ::) :soz:
DJ ;)
Offline GSS
    • artzone4u.com
Re:is there a way
« Reply #7 on: November 01, 2003, 09:24 »
ok i get the over admin comeing down today so i see if he can do it :) :thanks:
www.artzone4u.com
banner coming soon
Offline WhiteDevil
Re:is there a way
« Reply #8 on: November 01, 2003, 19:15 »
Eeerrrmmm, i suppose it could be done. It would be so complicated though it wouldnt be worth writing it :-\
Why dont you do it so that you have a seperate thing in your signature that you click each time you make a post (IE refers you back to your post when made remember...) then it increments by 1. It would then write the number to a .txt file somewhere on the internet, the script then outputs the number in the .txt file
Still difficult though :'(
dam Boyle
Owner, Director
www.Severn-Computers.com
Offline GSS
    • artzone4u.com
Re:is there a way
« Reply #9 on: November 01, 2003, 21:55 »
ok  :-\ :)
www.artzone4u.com
banner coming soon
