Author Topic: outlook express problems  (Read 3424 times)
Offline danlan02
« on: November 01, 2003, 11:43 »
hi guys and girls,hope you r all well.
the problem is in outlook i cant delete any messages.
i have about 1000 e-mails i want to clear but delete dont work neither does select all and delete it just freezes and crashes any help would be greatly rceived thanx yall
Re:outlook express problems
« Reply #1 on: November 01, 2003, 12:00 »
Hi danlan02 :welcome:
Have a look at this Microsoft Knowledgebase article.
I hope it helps :)
Edit: Typos corrected ;)
« Reply #2 on: November 02, 2003, 15:00 »
I have a another problem with Outlook Express. Whenever I open it to download mail it imports all my contacts from MSN. I keep deleting them but when I open outlook again they are back and I can't shut down msn when I am in Outlook Express.
« Reply #3 on: November 02, 2003, 16:42 »
I thought I knew this one, but I've been going through all the settings in Outlook Express, and can't find anything to connect it with Messenger.  Perhaps I was thinking of Outlook?  Sorry Lona, not much help to you.   :-\
You could always try Mozilla Mail!   ;) ;D ;D
« Reply #4 on: November 02, 2003, 17:11 »
Sandra told me a few days ago that there is a setting under tools/options in OE which will prevent Messinger from doing that, but it's not on my version.  I am totally unable to wield any control over mine despite trying every trick in the book.  It's disconnected at present but can turn itself on without warning at any time.  My OE is on at the moment too.  Oh, and of course it downloads all my contacts into my address book as well.  I would love to find a solution to these problems.  One which doesn't contain the letter "M" would be nice.   ;D
« Reply #5 on: November 02, 2003, 18:05 »
I can't find it in my OE either.  As you may remember, Clive, I had the same problem with Windows Messenger 4.7 taking on a life of it's own.  I have since updated to Windows Messenger 5.0 (download here), and the automatic signing on problem no longer occurs, but you have to make sure in both MSN, and Windows Messengers, that the boxes are un-ticked under Options > General to stop then starting automatically (see shot below).  Not sure if that will help Lona though.  There is definitely a setting in Outlook, but not OE, as far as I can see.
« Reply #6 on: November 02, 2003, 18:17 »
Thanks Simon.  I'll try that.  I notice that it's connected itself again without asking permission.
« Reply #7 on: November 02, 2003, 20:02 »
These are the options that I have in my Outlook Express 6  ???
It only mentions Windows Messenger as I told you before Clive so it wont be applicable to Lona for MSN Messenger :doggie:
« Reply #8 on: November 02, 2003, 20:40 »
I found this. I know how to get into regedit but don't know what a Dword is.  Could be a Dinah word for all I know. ???
To prevent MS Messenger from loading with OE you must do BOTH of these
things:
In Tools | Options uncheck the option to automatically logon to
Messenger.
AND
In View | Layout uncheck the Contacts Pane.
To just stop it from running follow this advice from Kelly:
"Only 3 Registry edits are required to stop Messenger and get rid of the
delay in OE.  Start/Run/Regedit
HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Messenger\Client
Add the following values as New, DWord Values:
PreventRun
PreventAutoRun
Set the value of each of these to 1
Go to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Outlook Express
Add a New, DWord value called Hide Messenger and set the value to 2.
(This step is required to prevent a long delay when opening OE with the
Contacts pane enabled)
« Reply #9 on: November 02, 2003, 20:52 »
I've cracked it guys. All you need to do is go into view and untick Contacts. :D. Does that make me an apprentice techie  ;)
« Reply #10 on: November 02, 2003, 20:55 »
Unfortunately you wont have any contacts showing then will you Lona  ???
« Reply #11 on: November 02, 2003, 21:17 »
I haven't got that option in mine Sandra.  I did run a 'remove messenger' program at some point, when I was having trouble with 4.7 automatically logging on, so maybe it removed that option from OE as well?  As I said to Clive, I now have Windows Messenger 5.0, as well as MSN6, and don't have the problem.
You could always try Trillian, Lona!   ;) ;D ;D
« Reply #12 on: November 02, 2003, 21:29 »
Removing contacts in Outlook Express does not remove them from MSN,Sandra, I have done it and it's ok, I still have all my contacts when I log on to MSN
« Reply #13 on: November 02, 2003, 22:14 »
I'm going to take Simon's advice and download Windows Messenger 5 tomorrow.  I will report back.   ;D
« Reply #14 on: November 02, 2003, 22:46 »
I was meaning your ordinary address book contacts too Lona, the ones you really want in your list not, just the MSN ones :doggie:
