Author Topic: ??? Herm ???  (Read 1097 times)
Offline twiggy
??? Herm ???
« on: November 02, 2003, 12:07 »
On my older pc i have just put another 20gb hdd in it set the jumper pins to slave and on the other 20gb hdd set the jumper pins to master. Now when i boot up the pc i keep pressin delete and cant enter the bios ??? why is this? I'm runing window 98. It's a hp pavillion bought about 3years ago.
Any ideas ???
Thanks Mark
Re:??? Herm ???
« Reply #1 on: November 02, 2003, 12:47 »
Have you tried going back to the original configuration, just to make sure it isn't a coincidental problem with your keyboard?
Anyway, according to this HP page you get to the BIOS by pressing F1. :-\ :-X  ::) ;D
Offline twiggy
Re:??? Herm ???
« Reply #2 on: November 03, 2003, 13:31 »
Ok thanks dats cool sorted it no.
