Author Topic: DUN Folder Question  (Read 901 times)
DUN Folder Question
« on: November 02, 2003, 15:46 »
Next weekend, I will be doing my half-yearly format.  My e-mail, documents, backups etc. are always saved to my d: drive.  What I do is drag them to c:, format d:, drag them back to the now clean d: and finally format c:.
It has just occurred to me that I could save my self a bit of faffing by copying my Dial Up Networking folder over to the clean d: before formatting c: and then replacing the empty DUN folder with my copy after I have re-installed Windows .
Would this work?
Re:DUN Folder Question
« Reply #1 on: November 02, 2003, 15:59 »
Try it  ;D
« Reply #2 on: November 02, 2003, 16:35 »
Don't see why not.   :)
