November 28, 2024, 01:47
Technical Help & Discussion
Software, Hardware & Website Recommendations
BitTorrent
Topic: BitTorrent (Read 1431 times)
Sandra
Ultimate Member
BitTorrent
November 04, 2003, 03:17 »
Does anyone have any experience of using this ? :
http://bitconjurer.org/BitTorrent/introduction.html
It sounds better than the P2P progs but is it complicated to set up and use
Robotochan
Established Member
Re:BitTorrent
November 04, 2003, 08:42 »
I use it a lot as there is a much less chance of downloading a file and being corrupt (well for me anyway). Best google "Shadow Bit Torrent Client" that might find the shadow client which reduced CPU usage by the program. Just install it, go to
www.suprnova.org
, click a torrent file from the list and it will download, same process as dat files for kazaa
b]Oxymoron: [/b]
Example:
Microsoft Works
Sandra
Ultimate Member
Re:BitTorrent
November 04, 2003, 13:21 »
Thanks Robo, how do you find it compared to the usual P2P ones for speed and availability ?
Robotochan
Established Member
Re:BitTorrent
November 04, 2003, 15:04 »
The good thing about BT is that it shows how many people are just sharing (Seeds) and how many people are downloading and sharing (Peers/leechers). I normally get around 2kb/s on my modem which to tell the truth is all I expect from Kazaa so it's fine
Availability is sometimes another matter as sometimes the torrent files don't work or for some reason just become dead...
b]Oxymoron: [/b]
Example:
Microsoft Works
DropShadow
New Member
Re:BitTorrent
November 05, 2003, 02:53 »
I've heard quite a lot about the program, though I haven't, myself, used it.
I use 'eMule' as my preferred client for downloading "hashed" links. Very nice prog.
http://www.emule-project.net/
Anyone needs any help on it, just ask. I *would* suggest anyone interested has an ADSL connection, though!
BitTorrent
