Hi people!
Ok, here we go:
Windows XP Home.
System boots OK.
When you open IE, it tries to locate the homepage. When it does, IE closes, and I am presented with the OPEN/SAVE dialog box.
If I somehow manage to get IE open, any link will give the same result.
IE properties have some missing tabs (General/Privacy/Content).
Tried to uninstall IE, seemed OK, have IE6SP1 on disc - seemed to install, but no icons placed.. IE not working now.
No spyware on system.
Tried to install NAV. It gets to the "Configure" stage - only a blank window is shown (instead of the yellow window with a NEXT button).
System Restore doesn't work - gives an error message "Cannot start, restart the PC and try again". If I get it up (sometimes) it is a blank window just like NAV.
Any suggestions!!?
Thanks
