Author Topic: Is it my monitor ?  (Read 3882 times)
Offline Michelle
    • Techieminx
Is it my monitor ?
« on: November 06, 2003, 14:33 »
Hi Guy,
Yet another on going problem I wonder if you can help with ......... is that my screen sometimes goes a bit darker and a bit reddy? Thats the best I can explain it.
It started off just doing it for a second now and then, so I just ignored it, (like you do)  but just lately its been staying like that for longer and doing it more often, is it finally going to go like that forever or is there a setting wrong ?
I've only had the monitor since xmas,it was a present.  I can't see a make on it? Its an TFT though ........ (wait for the I told you so's) Think I've got the box in the loft so that'll prob say what it is.
Any idea's Guys Please?
Don't know if this helps but I found the make on line.
http://www.comparestoreprices.co.uk/monitors/pro-em-em-150.asp
Re:Is it my monitor ?
« Reply #1 on: November 06, 2003, 14:43 »
I wouldnt have thought that it was a problem on the pc Michelle, more likely to be the monitor itself.
If it was a traditional CRT monitor then I would have said that it sounded like a dry joint but I havent a clue on TFT ones.
Have you got the receipt as it may be as well getting it exchanged while its still inside the guarantee period  ???
Offline Michelle
    • Techieminx
« Reply #2 on: November 06, 2003, 14:47 »
Hmmm I think you are right sandra cos it is getting worse but I was hoping that maybe something I'd done had effected it.
I might be able to get hold of the receipt though.
Thanks Sandra for your advice.
« Reply #3 on: November 06, 2003, 18:00 »
Before you go to the trouble of getting a replacement, Michelle, you could just check the connection from the monitor into the back of the PC.  They have been known to come adrift, which can result in your exact symptoms, on a CRT, so I would imagine a TFT could still suffer the same.
Offline Michelle
    • Techieminx
« Reply #4 on: November 06, 2003, 20:04 »
The connection, you mean the plug right, well oddley enough it wasn't in that tight and I could screw up the screws on the side. You think it could be just that??  :o  :-[  ;D
« Reply #5 on: November 06, 2003, 20:52 »
I would say you've definitely got a screw loose, Shell.
Offline Michelle
    • Techieminx
« Reply #6 on: November 06, 2003, 21:32 »
Not the first time thats been said rodders  ;)
« Reply #7 on: November 06, 2003, 21:34 »
Have you tried wiggling it about?
Offline Michelle
    • Techieminx
« Reply #8 on: November 06, 2003, 21:42 »
Yes often, its nice ........... oh the plug, yes I've wiggled and push and screwed it now and fingers crossed its not done it since.  ;D  I'm shocked if thats what it is, but pleased as punch if it is.  ;)
« Reply #9 on: November 06, 2003, 21:44 »
Well, the screws on the side of the connector are there to be screwed, Michelle!   ;)  See if that makes it any better.  I have a sneaking feeling it just might.   ;D ;D
Edit: Can someone swap these last two posts around?  :lol:
« Reply #10 on: November 06, 2003, 21:45 »
Oh, we're back to the bl**dy monitor again, are we?   ;D
Offline Michelle
    • Techieminx
« Reply #11 on: November 06, 2003, 21:48 »
Well and truly screwed now  :P  ;)  ;D
« Reply #12 on: November 06, 2003, 21:55 »
Hope you enjoyed it!
Offline Michelle
    • Techieminx
« Reply #13 on: November 06, 2003, 22:01 »
It was very enjoyable yes  :tongue:
« Reply #14 on: November 06, 2003, 22:01 »
Slack Alice?
