Author Topic: sound card not working!!!  (Read 889 times)
Offline carnaging
    • http://www.dazsdomain.tk
« on: November 10, 2003, 17:59 »
..right ok, here we go again, i posted a while back about graphics card not working, well i managed to resolve that problem by re-installing windows, i have tried doing this again but im getting no change, I run windows XP home edition , anyone got any ideas??  ???
¯`·._(~Ðãz~)¯`·._)
Re:sound card not working!!!
« Reply #1 on: November 10, 2003, 18:12 »
Would help if we knew what motherboard and soundcard :) . I take it you have disabled the one on the motherboard (they usually come with one fitted these days) - it will be in the bios , usually under 'peripherals' or 'advanced'.
Offline carnaging
« Reply #2 on: November 10, 2003, 18:16 »
im not 100% sure, im not on the computer that has the problem, im using another one at the moment, when i get back home i'll have a look and find out what sound / mother board im using! :)
¯`·._(~Ðãz~)¯`·._)
Offline carnaging
« Reply #3 on: November 12, 2003, 17:37 »
WAHAY!! ;D, i managed to sort it out, it was just a configuration problem, wish id'e known earlier! ::), thanks anyway though guys!! ;) - if anyone else is having the same problem, e-mail me, Daz_H16@H*o*t*m,*a*i*l.com -  and i'll explain how to resolve the problem;)
* Simon disguised Daz's email address to protect from spammer's scanners.   ;)
¯`·._(~Ðãz~)¯`·._)
« Reply #4 on: November 12, 2003, 17:41 »
Thanks very much for letting us know the outcome Daz.  Glad it's all sorted now.   :)
« Reply #5 on: November 12, 2003, 18:06 »
Glad you sorted it Daz but it would be helpful if you posted it on here, if you dont mind, in case others have a similar problem in the future  :)
